brake light
Old Oct 15, 2003 | 06:08 PM
banginis300's Avatar
brake light
would anybody have any explanation as for why the brake light on my dashboard stays on, even though my e-brake is completly down???
and if I somehow violently shook the car by for example braking really hard, it would make the light turn off for a very short while, yet always come back on
Old Oct 15, 2003 | 06:22 PM
funmax's Avatar
check your brake fluid.
Old Oct 15, 2003 | 08:31 PM
BSwithTF's Avatar
Yup, my wife's '96 did this before we traded it in. The fluid was right between the LOW and the MAX lines. I filled it to the MAX line and the light went out. It's wierd cause my '96 is right between the lines and the light doesn't come on.
Old Oct 16, 2003 | 08:36 AM
UncleMax98's Avatar
The fluid level sensor is not precise. If the floating magnet is too strong, it may activate the sensor at the bottom of the reservoir even though the magnet itself is above the low mark.
Old Oct 16, 2003 | 09:36 AM
dave harms's Avatar
check wiring
bypass the float switch, and see if you can toggle the light that way. if no difference can be made that way...
check the sensor at the parking brake, sometimes that switch can be problematic... bypass it and see if the dash light shuts off...
the problem is EXTREAMLY likely to be in one of these two places, both easy to access
good luck
dave h.
Old Oct 16, 2003 | 09:50 AM
BlueBOB's Avatar
mine has done this quite a few times... it has usually been low brake fluid. I've had it come on with low pads and heavy braking. I'll brake softly and no light, but i'll brake heavy and it'll come on... changed the pads... problem went away... of course, i also have a suspision that I have a very small leak somewhere. ordering SS lines soon.
Old Oct 16, 2003 | 09:53 AM
dave harms's Avatar
OK,
explain one thing...
which dash light comes on? the one for the parking brake, or your 'other' brake light??
...'cause in your first post, you mention that your e-brake is down...
thanks,
dave h.
Old Oct 16, 2003 | 10:43 AM
LastBoyScout's Avatar
cause you do too many e-brake slides. cut that out
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
