Car question!
Old Oct 18, 2003 | 05:37 PM
balla95_se's Avatar
Car question!
I just discovered a puddle of oil when i pulled out of my garage. I know it came from the car. Is this a bad sign? Is there a leak somewhere? Is it effecting my performance?milage? what would i need to do to fix it? How much would it cost? Thanks A LOT...
Old Oct 18, 2003 | 05:44 PM
Phatmax98's Avatar
If you can, get under your car..check to see where the oil is coming from. You might have a bad gasket, or loose drain plug. Aslo, have you bottomed out recently? That could have something to do with it. If you see where the oil is coming from, take it to a shop and have them check it out. As far as affecting your mileage or performance, you shouldn't have any problems, just make sure you check your oil level every day for a week, then if you don't have it fixed by then, check weekly. Hope this helps and good luck to ya.
Old Oct 18, 2003 | 06:08 PM
Jatan's Avatar
http://www.motorvate.ca/mvp.php/514
Old Oct 18, 2003 | 10:45 PM
NissanSE98's Avatar
ok...........uh fix the leak.....uh
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
MikesChevelle
Aug 10, 2015 10:53 AM
xUNIxPanther
Aug 5, 2015 09:31 AM
