KNOCK Sensor Changed~!
Old Oct 30, 2003 | 10:23 AM
97blackSE's Avatar
I just would like to thank www.skippynet.com for The guidance, and what tools to use. I tried myself before looking at any directions and WOW, i had no luck. I'm a 6'6'' dude, and i Have HUUUGE hands. I got me a 14'' extension and a swivel socket, and within half an hour, and one tiny cut on my hand, I had Succeeded! upon checkin the ecu? 0505!
Thank you skippynet and maxima.org...I CANT WAIT TO TEST DRIVE!
Old Oct 30, 2003 | 10:24 AM
vsamoylov
waht was wrong with your other one? did your car detonate?
Old Oct 30, 2003 | 02:23 PM
ivelweyz
yeah his car blew up. WTF kind of question is that? A KS doesn't stop your spark plugs from detonating in the engine. How else would the people with bad sensor still drive their cars???
Old Oct 30, 2003 | 03:30 PM
LastBoyScout's Avatar
L
O
L
Old Oct 30, 2003 | 04:20 PM
Shift_Power's Avatar
Hey, did it remove the hesitation?? Oh, and my retarded screw for checking the ECU is partially hiding behind the metal cover, hence I can't access it unless I take the metal plate cover off!! Frig!!!
Old Oct 30, 2003 | 05:20 PM
vsamoylov
no, i didn/t mean that the car blew up. i meant di the engine detonate, misfire,. My engines detonates on low gas like 87 here in ca, but runs perfect on 91. on 87, the valves hit the top of the piston and that is detonation.
Old Oct 30, 2003 | 05:43 PM
Chunger's Avatar
My other car is a Hybrid
Originally Posted by vsamoylov
...the valves hit the top of the piston and that is detonation.
Not quite....
Old Oct 30, 2003 | 07:42 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
uhmmm, NO dude.....
Old Oct 31, 2003 | 06:57 AM
astil's Avatar
You wouldn t want your piston to hit the valves, cause you d call www.car-parts.com and look for a new engine . Sometimes , silence is golden
Is always good to use the best octane if available. If you use 87 ,you ve got the answer to your problem ...
Old Oct 31, 2003 | 05:37 PM
vsamoylov
yeah, that is why i am using 91 now. no cheap gas for my baby. seems smoother also
Old Oct 31, 2003 | 07:11 PM
stephenlc's Avatar
I thought we could onyl use 92 and above?
Old Nov 1, 2003 | 10:26 AM
97blackSE's Avatar
91 and above only guys HEH...It removed all hesitation and the other nite i took my friend for a ride, right after i changed the sensor, and started a roll at 5 mph, And then put it to the floor...Didnt regain traction again until the top of 2nd gear when i used to do that with the bad knock sensor, the car would hardly chirp its tires!
gas milage has improved as well.. With a fair amount of hard driving, I am down to about 3/4 of a tank, with 110miles on the trip odo...
Old Nov 1, 2003 | 10:40 AM
vsamoylov
california only has 91 as the top gas.
Old Nov 1, 2003 | 10:49 AM
97blackSE's Avatar
That sucks... I can get 94 here!
Old Nov 1, 2003 | 12:22 PM
1FSTMAX's Avatar
Lucky bastard.....All I got is 91 octane..
Old Nov 1, 2003 | 12:40 PM
97blackSE's Avatar
trade me your computer, and i will send you all the 94 you want!
Old Nov 1, 2003 | 02:53 PM
ivelweyz
we got 87, 89, 91, 92, 92.5, 93, and 100...
Old Nov 1, 2003 | 04:14 PM
KWheelzSB's Avatar
Detonation = when the air/fuel mixture ignites/detonates before the piston reaches TDC (IE: piston is still travelling toward the cylinder head at the time of detonation) This is baaaaad, mmmkay.
Old Nov 2, 2003 | 08:57 AM
vsamoylov
yeah, i know that iti s bad. And the only things that come to my mind to I can stop that is use higher gas, which works but expensive in ca, replace knock sensor, I haven't tried that yet, and go to Nissan and ask then if the can decrease timing about 2 degrees, haven't tried that yet either.
Old Nov 2, 2003 | 11:36 AM
Ladzio's Avatar
Just replaced my knock sensor with new one, but cannot get resistance reedings from the other end of the harness, it shows nothing.
It looks like the wire in harness is ripped at some point, or what could it be????
I heard harnesses are quite expensive, up to 90 bucks, is that true???
Opinions Welcomed!!!
Old Nov 2, 2003 | 11:44 AM
Kevlo911's Avatar
Kevlo for President
VLad i can't read mine either but i don't have a ghost code stored in the ECU anymore so check ur codes. i felt a increase in power and i noticed more MPG
Old Nov 2, 2003 | 11:47 AM
Ladzio's Avatar
I'll do it now, but did not reset ECU since I put it in, so it may give the code again. I think I also got a power increase, but not really sure if it is true or just a Placebo Effect.
Old Nov 2, 2003 | 11:52 AM
Kevlo911's Avatar
Kevlo for President
reset it, drive A while and check codes again tomaro
bbsitum
Sep 6, 2019 07:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
