CV joint repair price
Old Dec 1, 2003 | 09:05 PM
crashmanmike's Avatar
Anyone have any idea how much a good repair shop will charge to replace a CV joint on my '96 Maxima?
Just curious so I don't get ripped off. I'm estimating about $600-800 with labor and all, but I really have no idea.
Mike
Old Dec 1, 2003 | 09:07 PM
ABK's Avatar
ABK
That's funny. You can get the whole axle for $55 from autozone. If you are not technicaly incompitant you can get one of these guys that live somewhere around you to replace it for you for $200 and they will be glad.
Old Dec 1, 2003 | 10:38 PM
Lonely Driver's Avatar
Usually $150-$200 to replace a drive axle. Around the same for a cv joint. There are 2 cv joints on one axle so it is better to replace the axle instead of just the joint.
Mike
Old Dec 2, 2003 | 12:35 PM
95MaxSE's Avatar
Mike
In Houston, TX, you can have the whole CV joint axle replaced for $100 each.
Old Dec 2, 2003 | 01:11 PM
ABK's Avatar
ABK
Get the axle from autzone for $55 and get over it
Old Dec 2, 2003 | 01:34 PM
maxcross's Avatar
labor at nissan is $130, but just about any mechanic is capable of replacing an axle without destroying anything. It's easy to do with a lift, and it really only takes 15 mins if you know what you are doing. Unfortunately, most shops charge 1 hour minimum, so you kinda get smacked on labor. Be careful of the cheap axles. I bought one from napa for $150 including core charge and it may be defective. I'm getting it checked out at Nissan on Saturday to see if that is definately still a problem, or if there is a deeper rooted issue that is making a metal on metal rubbing sound when I turn to the right, and is causing a really nasty vibration from the LH front wheel. Cars...love em and hate em all at the same time.
Old Dec 2, 2003 | 02:34 PM
Kevlo911's Avatar
Kevlo for President
55$ for axle at autozne and for me it was less then 50$ for labor at firestone.
Old Dec 2, 2003 | 02:41 PM
NmexMAX's Avatar
dot dot dot ...
Yeah, never go to the dealer, because that what their price looks like, they try and rim job 'ya everytime.
Old Dec 3, 2003 | 09:43 AM
Wow. Thanks guys. This might be a good Christmas after all!
Mike
Old Jan 10, 2013 | 05:12 PM
joepatrickmartin's Avatar
Just wanted to say, I found this forum very helpful. I am having the aforementioned rubbing/grinding sound when I turn to the right. I am going to try replacing the cv joint and I will reply when I get it done.
Old Jan 10, 2013 | 05:19 PM
ShocknAwe's Avatar
A lot of people automatically assume noise when they are turning is from a bad axle. It could also be the strut insulator. That gives more of a squealing noise though
Old Jan 10, 2013 | 06:52 PM
asand1's Avatar
Originally Posted by joepatrickmartin
I am having ... rubbing/grinding sound when I turn to the right.
It's very likely the Left wheel bearing. Can't tell without being there. Bad CV joint makes a clicking/knocking sound while driving through a turn.
AaronL
Nov 15, 2020 11:52 AM
bbsitum
Sep 6, 2019 07:31 PM
jc53
Oct 6, 2015 06:00 AM
dcam0326
Sep 8, 2015 11:02 PM
