engine swap
Old Dec 13, 2003 | 09:52 PM
y_boy100's Avatar
engine swap
did anyone try to put a 5th or 6th gen engine into a 4th maxima? would it be work? and what kind parts i need to do all this kind job?
thanks
Old Dec 13, 2003 | 10:19 PM
vsamoylov
i did it. You need a lot of things. the only prtoblem will be with the intake manifold because 2k maximas are not throtle controlled, i think. 4th gen maximas have the throttle cable and 5th have electronic.
Old Dec 13, 2003 | 11:09 PM
KsuMax's Avatar
Cheesing away...
don't even bother. not worth the effort.
Old Dec 14, 2003 | 01:59 AM
PeTeRtheEaTeR's Avatar
if u wanna spend that much money, just get a supercharger or a turbocharger and save!
Old Dec 14, 2003 | 05:55 AM
Kevlo911's Avatar
Kevlo for President
95-01 are throttle cable driven, 02+ are drive by wire. if u did the swap from the 01/00 engine you should know this
Old Dec 14, 2003 | 10:18 AM
vsamoylov
and 2k2 re electronic and no cable at all. i know the difference. plus you will have to reroute all the hoses cause 2k have a thermostat for the engine and 4th gen don't have that thermostat. if you want to have something rare and you could prove it, go for it. i did and i know that i have it but hard thing is to make people believe it.
Old Dec 14, 2003 | 10:38 AM
y_boy100's Avatar
how does it work? lot faster? and what kind engine u put into, 3.0 or 3.5
Old Dec 14, 2003 | 10:46 AM
DoGGy
thanks
may i ask why u want to do a swap?
Old Dec 14, 2003 | 06:17 PM
vsamoylov
well I put a 3.0 2k engine into it. it feels more powerful than a stcok same year max. my friend has one and were both auto. I took him off the line and he was way behind me and then we tried it the other way and i could not pass him. Maybe it is because I also have a 2k ypipe and bpipe? the reason i did it because my brother did a 3.5 swap on his car and i took the 3.0 engine and swapped it into mine because we had too much free time and a spare brand new engine. my max has 99,xxx on it and the engine and tranny have 15,xxx
Old Dec 14, 2003 | 07:30 PM
y_boy100's Avatar
is that possible to put 3.5 into a 99, how does it feel. and what kind parts i need, i max is a 99 auto, i want a 3.5 maneul there, is that hard?
the reseon is i like the NA engine very much, don't like tubor or superchager engine that much.
Old Dec 14, 2003 | 07:34 PM
MaxedOutOfCash's Avatar
Pizda Boy
Wait, what? A 4th gen has no thermostat? It's in a thick, wide hose at the fron left of the engine I believe.
Old Dec 14, 2003 | 07:47 PM
Ladzio's Avatar
Man, you did a swap and you don't know that 4th gen do have thermostat...
4th gen do have thermostat, it's on the engine block inside the fat hose where coolant enters going out of radiator.
Old Dec 15, 2003 | 10:20 AM
vsamoylov
yeah, ok i admit that i did not know where the hermo is on the 4th gen but i know that the thermo on the 5th gen is on the right side of the intake manifold. mine is hidden because it is covered by a bunch of hoses that 4th gen don't have.
Old Dec 15, 2003 | 11:39 AM
KsuMax's Avatar
Cheesing away...
I'm calling major bs on the 3.5 into a 4th gen swap until I see pics
Old Dec 15, 2003 | 11:54 AM
techie's Avatar
I think what he was saying is that his brother has a 2k and swapped the 3.0 with a 3.5 and they put the 3.0 from the 2K and dropped it into the 4th gen.
Old Dec 15, 2003 | 11:59 AM
KsuMax's Avatar
Cheesing away...
Oh, I see now
Old Dec 15, 2003 | 12:17 PM
KsuMax's Avatar
Cheesing away...
vsamoylov I have a question for you.
Mine
Your's
And a 2000
Mine and yours looks pretty similar, and you claim that you have a 2000 engine in your car. Then why do you not have the 5th gens intake manifold?
Old Dec 15, 2003 | 12:34 PM
matty's Avatar
The only difference's are the cam size and the manifold is alittle higher on the 5th gen cause its the variable intake controlled by the computer...
I dont know why it wouldnt work, but you would have to use a 4th generation intake manifold...the 5th manifold wouldnt let the hood close
-matt
Old Dec 15, 2003 | 12:53 PM
mzmtg's Avatar
Minister of Silly Walks
We've been over this with vsamoylov before. He did swap a 5th gen engine into his car. There's a thread with pics and proof, search for it. He had to swap many of the 4th gen components over to the new engine for it to work.
But, he did it.
EDIT: here it is
http://forums.maxima.org/showthread.php?t=258557
Old Dec 15, 2003 | 01:17 PM
KsuMax's Avatar
Cheesing away...
I didn't know there was thread about it, my bad.
Old Dec 15, 2003 | 06:09 PM
vsamoylov
also compresion is different and pistons are bigger also according to my bro.
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
seesole
Sep 14, 2015 12:38 PM
I<3 A32's
Sep 10, 2015 11:07 AM
