wtf did I do
Old Jan 1, 2004 | 10:02 PM
JS MAX's Avatar
wtf did I do
I was checkin out my courtesy lights and touch where the bulb plugs in and now they dont light...checked all my fuses and none are blown...could it just be the bulb or wha?
Old Jan 1, 2004 | 10:52 PM
BORQUA79's Avatar
nycmaximas member
I did the same about a year ago and I still cant figure it out...I even switched the whole harnest from my driver side that did work to the passenger side that doesnt and still nothing??? I might have fried some wire??? Anyone else know any answers?
Old Jan 2, 2004 | 12:42 AM
DR-Max's Avatar
First, check the switch. Make sure the switch is either on the ON or DOOR position. Then check both sides of the lamp socket using a light tester. Check to see if you are getting 12 volts from any of it. If so, its the bulb. If not, it could be your fuse. But you already mentioned that the fuse is good so it could be the lamp socket terminals or wiring from the fuse to the lamp socket.
Old Jan 2, 2004 | 10:56 AM
ManualMaxima's Avatar
5th Gen till she dies!
bad ground??
Old Jan 2, 2004 | 01:43 PM
ohannon7's Avatar
My lights mysteriously shorted out once too. It turned out to be a fuse that I didnt think would have anything to do w/ lights. I cant remeber if it was in the cabin or under the hood though. Just spend 30minutes and check every single fuse....
Old Jan 2, 2004 | 02:24 PM
Nismo's Avatar
I burned mine out too. From what ppl told me, I have to buy a new door switch. I guess thats where it shorted out in
Old Jan 2, 2004 | 06:17 PM
JS MAX's Avatar
dammit..what is the part exactly that needs to be replaced..my locks and windows still work fine but its just the courtesy light that doesnt work. Is my only option to head to the dealership and have them replace it?
Old Jan 2, 2004 | 06:49 PM
DR-Max's Avatar
I think he's referring to the pin switch that the door hits when it closes, it breaks or makes the circuit to turn the courtesy light on or off. I'm not sure if that switch is dealer specific but it just might be. If you are somewhat electronically inclined, you can test that pin switch. If not, perhaps you need to enlist the help of an automotive electrical shop.
Old Jan 2, 2004 | 06:56 PM
Jepht20's Avatar
Custom User Title...
check the fuse in the middle row 3 down...that's what was blown on mine.
Old Jan 2, 2004 | 07:51 PM
JS MAX's Avatar
checked..its fine. I wish it was just a fuse. I guess I'm going to be callin up a shop soon
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
