Bouncing RPMS
Old Jan 14, 2004 | 06:46 PM
MrJimmyHoffa's Avatar
Bouncing RPMS
Alright, It could just be that im noticing it now, but after acclerating my rpms drop to 500 then bounce back up to 1000. If this isnt supposed to be happening whats causing it?
Old Jan 14, 2004 | 07:23 PM
trubd's Avatar
try cleaning yr tb maybe it will help
Old Jan 14, 2004 | 07:59 PM
azmaxipad's Avatar
mine has the same problem what's the tb?
Old Jan 14, 2004 | 08:01 PM
Nismo's Avatar
Throttle Body. mines clean, mine does that, pretty shure its normal for 5speeds. you have a 5sp right?
Old Jan 14, 2004 | 08:24 PM
happyricefob's Avatar
V^___^V
clean throttle body, make sure your engine coolant temperature sensor is working properly. is your MAF sensor plugged in? air filter clean?
Old Jan 14, 2004 | 08:27 PM
Defacto's Avatar
if his MAF sensor wasn't plugged in, his car would die. Check your TB....
Old Jan 14, 2004 | 08:28 PM
Defacto's Avatar
sorry, it wouldn't die, it wouldn't rev past 2k RPMs...
Old Jan 14, 2004 | 08:33 PM
azmaxipad's Avatar
5spd, new filter, i heard its normal w/ stock tachs though ????
Old Jan 14, 2004 | 08:35 PM
G20Flyer's Avatar
I'm not sure i get the question...can you explain a little better.
Old Jan 15, 2004 | 12:49 PM
Thanx for the help, ill take a look at the tb and filter this weekend.
It is a automatic
G20Flyer: after I acclerate the rpms will fall from like 3000 all the way to 500 then go up to 1000
also, it hasnt been starting on the first try lately, could this be another sympton of whats causing the rpms?
Old Jan 15, 2004 | 12:54 PM
hotmax97's Avatar
mmmhhh no ! why would it be normal ?unless you don't know how to steo on the clutch
Old Jan 15, 2004 | 02:38 PM
Nismo's Avatar
because I believe it has something to do with the idling circuit bumping the rpms back up when it senses it drop after a neutral rev,
Well, mine doesnt jump back to 1000rpm like he says but after a quick rev in neutral, it dips down and jumps back to idle speed....maybe my lightweight flywheel has something to do with it... oh well
Old Jan 15, 2004 | 05:17 PM
mine is auto..
Old Jan 15, 2004 | 05:31 PM
Nismo's Avatar
again, I used to be auto and it did the same thing so......
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
slowlifer
Sep 8, 2015 05:53 AM
