bad motor mounts?
Old Jan 17, 2004 | 01:03 AM
cyjad's Avatar
bad motor mounts?
Since I can't do a search, how does one know if their motor mounts are going bad?
Old Jan 17, 2004 | 02:23 AM
ABK's Avatar
ABK
When your car jerks alot, thru shifts. Also it might pull to the side when you give it gas or let off the gas. Alot Wheel hop when launching the car. Look at them
Old Jan 17, 2004 | 06:44 AM
BRAVO's Avatar
i just replaced all my motor mounts and my tranny mount with aftermarket mounts for 200 in my 97 max. because mine went. If you want the guys contact info email me @ bravo713@aol.com
Old Jan 17, 2004 | 09:27 PM
nismos14's Avatar
§è~® f®ÈÄk
hey im interested in the info, did you get them installed for $200?
Old Jan 18, 2004 | 11:10 AM
joaquink's Avatar
¿Hablas Español?
You'll feel the engine rolling too much and it will move the car with it.
Set your parking brake and place load on the engine while in gear. As you move into gear (auto or manual, though for manual, you'll have to modulate the clutch) and out of gear, you'll be able to sense whether there is too much play. Then check the other half of a possible problem by creating load in reverse.
Visually, you can inspect the motor mounts by looking for tears, brittleness, flaking, etc. If you want to know where they are, read through the FAQs, buy a Haynes manual or FSM and get a little dirty working on your car.
I did the shore 80-a (or however that works) homemade poly-filled mounts per Eric's instructions. I think they're absolutely incredible and should be what Nissan provides from the factory. I have absolutely no complaints about vibration or noise.
Cheers,
Joaquin
Old Jan 18, 2004 | 11:23 AM
SuperFishstick's Avatar
i get plenty of wheel hop. What do u guys think about the PR motor mounts? They are around $200 or so right? Worth the money?
Old Jan 18, 2004 | 12:07 PM
bosa1's Avatar
How to in the FAQ sticky
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
Vequity
Sep 10, 2015 05:26 AM
