KS replacement results..
Old Jan 18, 2004 | 02:13 PM
michaelnyden's Avatar
how come my car was redicously fact the first day i put in the KS, then it just got slower from there and now...my acceleration and power delivery feels like it is back to the way it was before with the bad knock sensor...but this KS is fine...it tests fine and i get not cel when i try to pull it off the ecu...!>! should i loosen the bolt on the KS or tighten it more or somethin? did my car re learn some knock? i always have used premium gas...what gives? maybe i should just try resetting the ecu....that always gives me the gain back for like a day which is weird!
Old Jan 18, 2004 | 02:31 PM
DAVE Sz's Avatar
Hooooooonda.....
Was the one you replaced busted for sure? I'd say injectors are going bad. Have the exact same problem, new KS but car is still slugish. Just check the injectors you can get to, front 3 and 1 or 2 in the back. Use a screwdriver and put the metal tip to the injector and the other end to your ear. It should be clicking very fast, if not it's going bad.
Old Jan 18, 2004 | 03:02 PM
CullenJ76's Avatar
you're probably just getting used to it.
Old Jan 18, 2004 | 03:15 PM
happyricefob's Avatar
V^___^V
check for ghost 0304s. sometimes CEL won't pop out until you pull the code manually, it'll show. after that try to reset it and drive it around and then pull the code manually see if it's back. if it does, make sure you torque your knock sensor correctly, 15-20lbs i believe.
if none of these apply, probably just like cullenj76 said ur not gettin used to it yet.
Old Jan 18, 2004 | 03:48 PM
yeah i think i torqued it wrong...but i don't know fer sher...my injectors are clicking very fast! however, I have no codes, but i will try resetting my ecu anyway...because everytime i do that...my car seems faster for a day or two...! not just in my mind either! i do tests such as a first gear from 3000 roll, then floor it....my 235's spin when i reset my ecu all the way through first, but now they grip in first....i might try relocatting my knock sensor, cause i heard that might work from other members on the org here.....detecting false knock is the issue, so they relocate it where there is less engine vibration...
Old Jan 18, 2004 | 03:57 PM
nismos14's Avatar
§è~® f®ÈÄk
maybe the harness is bad too check it out
Old Jan 19, 2004 | 01:49 AM
no codes no matter what i do....i have pulled it so many times....i dunno, maybe i am getting used to it...but according to my "well-calibrated" butt dyno, im not...it just pulled really hard the first day after I replaced the KS....i mean spinning from a roll in 1st at 3000rpm then floor it, spin all the way through first on grippy 235/45/zr17's mind you and now my car grips in first gear meaning there isn't enough power to break 'em loose anymore! I haven't tried resetting the ecu yet though....usually when I do that my power comes back for a day...so it couldn't be my injectors as stated above...
Old Jan 19, 2004 | 01:55 AM
-=PK=-Maxima's Avatar
come to the install meet this sunday and we could check it out for you.
Old Jan 19, 2004 | 02:33 PM
install meet? where? im goin to the dyno day in torrance this saturday to see if something is wrong with my car...but I have the frankencar intake, warpspeed y pipe, high flow cat, b pipe, and technosquare ecu....what kind of numbers should i be putting down to the wheels (i have a 5spd) so i know after the dyno if something is wrong or not...such as the knock sensor!
Old Jan 19, 2004 | 02:42 PM
DCM Maxima's Avatar
Besides that you probably got used to the power increase that can happen to
Old Jan 19, 2004 | 02:59 PM
mrnock's Avatar
instal meet is sunday. look at the thread mevi bbq install meet
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
