Do 4th Gen Maximas (auto) have a transmission filter?
Do 4th Gen Maximas (Auto) have a transmission filter? The Haynes repair manual (p 1-25) recommends changing the filter when the fluid is changed. Is it a screen or filter? and does it need to be changed/cleaned when the fluid is changed? This manual covers 3rd and 4th gen Maximas so I am assuming that it is referring to both of them when it states this.
I am going to have my transmission fluid changed soon, the garage uses a T-TECH machine which I believe does what the magic sucker pump (Recommended by D.B. Martin) does...sucks all of the old fluid out of the transmission and replaces it with the new stuff. From what I was told this machine taps into the transmission lines that go to the radiator. It then uses the natural forch of the transmission fluid in circulation to clean and remove the old fluid while pumping in new fluid.
This procedure is supposed to clean the transmission and change the fluid without ever opening up the transmission. The Haynes maunal refers to 2 magnets in the pan that cache small metal particles that should be cleaned. Will they be cleaned if the pan using this machine? Are there any disadvantages to this kind of sucker pump procedure?
A long-winded discussion
Originally posted by VQMaxSE
... Is it a screen or filter? and does it need to be changed/cleaned when the fluid is changed? ...
This procedure is supposed to clean the transmission and change the fluid without ever opening up the transmission. ...
... The Haynes maunal refers to 2 magnets in the pan that cache small metal particles that should be cleaned. Will they be cleaned if the pan using this machine? ...
... Are there any disadvantages to this kind of sucker pump procedure?
My Maxima is a 5-speed so the issue of ATF change does not apply. I maintain a Honda Accord for a family member. On that car I do a drain-and-refill ATF change with every oil change. It is not a big deal, as the car is already up on jackstands and my hands are already dirty. This costs about US$8/year in ATF and the car is always running on almost-new ATF.
I would strongly recommend that you do NOT attempt to change the screen. The screen is held in place by cap head screws except in one location, Nissan used a bolt with a nut. If you remove the the screen, you will have to remove the valve body the tighten this nut and bolt. You really don't want to mess with the valve body unless you know what you are doing.
Cap screws
Originally posted by sinewave
I would strongly recommend that you do NOT attempt to change the screen. The screen is held in place by cap head screws ...
When I had my transmission fluid changed last time, I did have my filter changed. The guy at AAMCO said that most Maximas don't have a filter to change. But when he did mine, however, he did find one. My Maxima is a 95 auto purchased in 94. Perhaps a screen was used in the later models.
Informative article on "magic sucker pumps." The machine my local garage uses is a T-TECH which attatches to the coolant lines. The cost is $69 so I guess I can pay them extra to clean the magnets or just leave them alone. Any recomendation?
The article stated "and now are getting them to dump the old brake fluid every couple of years to avoid a megabucks ABS problems" How often should a brake fluid flush be performed?
Thanks for the reply Daniel Martin, from what I have read on this forum, you seem be very knowledgable about cars...were you ever a mechanic?
The only way to clean the magnets is to drop the pan. If you already have the pan off, then clean them but I wouldn't take the pan off just for this; once they have captured metal particles, they won't be re-released in the fluid.
by Bob Freudenberger
http://www.motorservice.net/ms/archi...600/0600tf.asp
"Some people say you can just use the machine and avoid the trouble of removing and cleaning the pan and replacing the filter. We beg to disagree. In the first place, it would be thoroughly uncraftsmanlike not to pull the pan to both clean out the heavy residue no amount of flushing will remove, and to see what's in there--shavings and big pieces of clutch material are an indication of a terminal condition"
I'm considering paying the extra money and having them remove the pan to clean it. My 97 SE has almost 60K miles on it. Any opinions?
Any idea on when you will be offering the Valve Body mod again Don? and what the price will be? I'm mostly concerned with extending the life of my tranny, the performance increase would just be an additional benefit. Is there any proof that a VB upgrade extends the service life of the tranny? I don't have a lot of knowlegde when it comes to transmissions but I hope to keep this car for a long time without spending a fortune in repairs. One of the reasons I bought it was because of it's reliability.
Any idea on when you will be offering the Valve Body mod again Don? and what the price will be? I have almost 60K on the car now and I'd like to service the tranny soon.
Do you think a person who mainly does easy repairs/maintenance (eg oil, filters, brakes, plugs, etc) would be able to replace the VB?
... I guess I can pay them extra to clean the magnets or just leave them alone. Any recomendation?
... The article stated "and now are getting them to dump the old brake fluid every couple of years to avoid a megabucks ABS problems" How often should a brake fluid flush be performed?
... Thanks for the reply Daniel Martin, from what I have read on this forum, you seem be very knowledgable about cars...were you ever a mechanic?
Originally posted by Don in Texas
Just do the whole thing when you get the Valvebody upgrade. You have to pull the pan and the screen anyway. Save big $$$$ and do it at once, ALL in about 2-3 hours.
Don
Don
Lakersallday24
Nov 7, 2024 07:31 PM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
