4x4 Skyline
Old Jan 24, 2004 | 10:02 PM
CiViC KiLLeR's Avatar
4x4 Skyline
Will a skyline body kit hit the ground if I lower my car? If so do I have to leave my max looking like a 4x4. What springs should I use with the skyline kit?
Old Jan 24, 2004 | 10:09 PM
SXN's Avatar
SXN
well...how much are you lowering it? what are you looking for? etc...be less vague
Old Jan 24, 2004 | 10:11 PM
I say maybe 1.5 in the front and 1.3 in the rear.
Old Jan 24, 2004 | 10:16 PM
I would like to get a Tokico Illumina Suspension Kit. What do you thank?
Old Jan 24, 2004 | 10:18 PM
ch13f's Avatar
Uhm, well it won't be touching the ground just sitting there parked, obviously.. but if you drive over a speed bump/curb/driveway entrance too fast then yes, you'll probably leave piece of the kit on the ground. For a 1.5" /1.3" drop, the closest would probably be H&Rs
Old Jan 24, 2004 | 10:20 PM
SXN's Avatar
SXN
that isnt that low. i really think the skyline kit would clear that, but like with most lowering jobs you would scrap on certain driveways and such. a little lowering ties the entire look together.
Old Jan 24, 2004 | 10:30 PM
So do not get a Tokico Illumina Suspension Kit. Why???
Old Jan 24, 2004 | 10:48 PM
SXN's Avatar
SXN
.....did anyone say not to?
Old Jan 24, 2004 | 10:51 PM
Sorry, I meant to say will they work instead of H&Rs. Which one is lower? (H&Rs or Tokico Illumina Suspension Kit)
Old Jan 24, 2004 | 11:01 PM
SXN's Avatar
SXN
The Tokico springs have a drop of 1.5" in the front and 1.3" in the rear. They have a spring rate of Front: 111 � 225 lb/in and Rear: 148 � 295 lb/in which probably puts them around the same stiffness as H&R. Tokico Springs are new and not much is known about them yet. They should be paired with Koni Yellows, KYB AGX, Tokico Illuminas, KYB GR2, or possibly Tokico Blues.
The H&R Sport springs have a 1.4" front 1.3" rear drop and are known to be the softest aftermarket spring for the 4th Generation Maxima. They are definately stiffer than stock SE springs, especially at their bottom limit due to the progressiveness of the spring but out of all the setups, probably the softest and most comfort oriented. They should be paired with Koni Yellows, KYB AGX, Tokico Illuminas, KYB GR2, or possibly Tokico Blues.
*edit* btw, i got this off of
http://maxmods.dyndns.org/index.php
one of the most helpful max sites ever
Old Jan 24, 2004 | 11:11 PM
Thanks for the help SXN.
Old Jan 24, 2004 | 11:21 PM
SXN's Avatar
SXN
nooo problemo.
Old Jan 25, 2004 | 07:31 AM
nissanfreak's Avatar
would a stillen lip with tien s tech and tokico Illuminas still have good ground clearance? Just curious
Old Jan 25, 2004 | 07:57 AM
96white's Avatar
Why doesn't someone recommond the Eibach pro kit? Is there a dislike for that kit?
Old Jan 25, 2004 | 08:58 AM
ch13f's Avatar
^ Its a very very stiff setup
Old Jan 25, 2004 | 02:58 PM
SXN's Avatar
SXN
eibach is very stiff, without being all that low. you can get a much better set up
LeoB
Feb 12, 2001 08:17 AM
Frezny
19
Jan 13, 2001 01:09 PM
Frezny
Jan 12, 2001 04:08 PM
SeR
Nov 27, 2000 07:47 AM
SCCA Solo2
Oct 7, 2000 01:46 PM
