Is this hole in my tranny supposed to be here?
Old Jan 26, 2004 | 12:38 PM
Bmr4life's Avatar
Is this hole in my tranny supposed to be here? Leaking Fluid Help!!!
I've got a pretty bad trans leak and I found this hole. Also, the bolts that hold the seam of the tranny together are stripped so it might not be the hole. I plan on using some JB Weld to seal this up cause its leaking pretty bad. thanks
Old Jan 26, 2004 | 01:49 PM
Bmr4life's Avatar
anyone know where I can get new bolts or what thread and size the bolts are? I'm trying to get some longer ones. thanks
Old Jan 26, 2004 | 08:26 PM
maxtrax's Avatar
[QUOTE=Bmr4life]I've got a pretty bad trans leak and I found this hole. Also, the bolts that hold the seam of the tranny together are stripped so it might not be the hole. I plan on using some JB Weld to seal this up cause its leaking pretty bad. thanks
It's not a hole, I believe it's a notch. These notches are use to help separate the two pieces that are bolted together. First you have to remove all the bolts. Then, with a flat screw driver placed in the notch, you can pry aprt the two parts.
Old Jan 26, 2004 | 09:43 PM
SXN's Avatar
SXN
that isnt a hole like maxtrax said, it sounds like a gasket issue.
Old Jan 26, 2004 | 10:00 PM
maxima98vspec's Avatar
its supposed to be there because when u take the tranny apart u can stick a flat head in there and pry it open easier. yea like they said it might be just a gasket problem that is leaking if tehre is any gasket, im not sure of that haven't taken my tranny apart yet.
Old Jan 26, 2004 | 10:08 PM
Bmr4life's Avatar
thanks for the replies guys. I'm pretty sure it leaking due to the two lower bolt holes being stripped out. i bought some longer bolts from lowe's and will see if that helps out any as well as putting the jb weld on there. thanks again
edited for a lot of sp errors
Old Jan 26, 2004 | 10:13 PM
Originally Posted by Bmr4life
thanks for the replies guys. I'm pretty sure it leaking due to the two lower bolt holds being stripped out. i bought some londer bolts from lowes and will see if that helps out any as well as putting the jb weld on there. thanks again
yea i think it would be the bolts cause that's the only thing that can cause leaks.
Old Jan 26, 2004 | 10:20 PM
Bmr4life's Avatar
one more question, i stripped both holds when i mistook these botls for the ones on the little trap door. I had already taken them both out when i realized they were the wrong ones and when i put them back i stripped the hole thats towards the back. I was using nothing but hand power and wasn't even in a good position to turn the wrench that hard. Should the hole have stripped so easily?
Old Jan 26, 2004 | 10:26 PM
SXN's Avatar
SXN
my guess is no, they shouldnt have. how many miles does your car have...would it have any reason to be old or worn out? also, did you really lean into it or not?
Old Jan 27, 2004 | 01:38 AM
izzydig's Avatar
reminds me of when I tried to seal a rear main seal on an old mitsubishi. it's looked easy to just fill in holes with sealant, but it wasn't.
Secondly....if you got stripped bolts only....try those re-tap kit's...or an experienced auto shop. They should be able to retap threads into the stripped ones and use new *matching* bolts. I've yet to have to retap holes, but that's just my own experience so far.
It's quite easy to strip bolts...remember to use your hands only to thread in old bolts next time...and use a torque wrench to torque down properly...they are only $20 nowadays (torque wrench).
Me thinks whoever "re-built" your tranny last time, screwed up ( didn't use torque wrench and/or didn't use proper seal components). I wonder if that seam that is leaking ain't your rear main seal. I've never had to deal with a rear main leaking on my max...yet. any comments?
Old Jan 27, 2004 | 02:17 PM
Bmr4life's Avatar
the trans is a replacement trans installed about 30K miles ago. when it was put in in it had 40k miles on it so now its around 70k miles. when you say really lean into it, are you talking about when i was tightening the bolts? if so, then no i wasn't, mainly because i couldn't even adjust myself to get great leverage. I bought some longer bolts and will try those tommorrow, hopefully they can reach in a little further and grab some more of the trans case without stripping it any further.
Old Jan 27, 2004 | 06:03 PM
SXN's Avatar
SXN
i agree with izzy, sounds like someone messed up your trans already. that part of the case shouldnt undergo much stress, and accord to you, you didnt apply nearly enough force to hurt it
Old Jan 27, 2004 | 06:28 PM
Bmr4life's Avatar
well i got some longer bolts and managed to get them in there. i tightened them until i was scared to tighen them any further. I have a torque wrench, but its impossible to fit it in there so i just had to go off feel. i'm still in the process of changing my 02 sensors, so i'm not driving it yet.
fx4five
Oct 18, 2015 06:57 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
fx4five
Oct 1, 2015 04:58 AM
maxima297
Sep 30, 2015 03:32 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
