Loose Wobble Wobbling Camshaft
Old Feb 3, 2004 | 10:33 PM
izzydig's Avatar
Today, I added in some UV dye to figure out a leak. I figured it out...but a friend of mine notice one disturbing thing.
When I removed the engine oil cap to put in UV dye, he noticed the camshaft wasn't running in a perfect line. It basically moves up and down about a 1mm out of line.
I have noticed no noises relating to this. It seems to run fine...but when you look at the intake (or exhaust...don't remember) camshaft running...it moves about 1mm? Have any of you ever noticed this? Is this normal at all?
It doesn't seem normal at all, but it looks bad ...yet...the car seems fine. Basically the camshaft seems to run about 1mm out of line. Can anyone explain this?
Remove the oil cap and see for yourself!
Old Feb 4, 2004 | 04:36 AM
njmaxseltd's Avatar
If you had 1mm of movement from your camshaft the noise your valvetrane would make would be very alarming.
I doubt what your seeing is play.
Old Feb 4, 2004 | 06:07 AM
Stephen Max's Avatar
Is that 1 mm TIR on an unmachined surface? If so, no big deal. As long as the journals and the bases of the cam lobes are concentric.
Old Feb 4, 2004 | 08:20 AM
Dreizehn's Avatar
123456789
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
viperboy
Sep 27, 2015 07:05 PM
220k+ A32
Sep 23, 2015 03:38 PM
dcam0326
Sep 8, 2015 11:02 PM
