looking for a VQ30DET.....look what i've found.
Old Feb 19, 2004 | 10:39 AM
maxima98vspec's Avatar
i went on yahoo and started looking for some VQ30DET and look what i've stumbeled on........ http://www.autospeed.co.nz/cms/article.html?&A=0206 ..... Its preaty cool how many different motors nissan made, i wounder if any of thoes internals would work for out cars like the VQ30DET's do.
Old Feb 19, 2004 | 12:35 PM
Scott_98Max's Avatar
Rock on!
There's also this little tid-bit of information...Check it out.
http://www.freshalloy.com/site/featu...nes/home.shtml
Take it easy!
S9
Old Feb 19, 2004 | 12:53 PM
Phatmax98's Avatar
Here ya go
VQ30DET
Old Feb 19, 2004 | 01:37 PM
AKM2k5's Avatar
Originally Posted by Phatmax98
Here ya go
VQ30DET
Does anyone know if a vq35 will fit in a 4th gen engine bay?
Old Feb 19, 2004 | 01:58 PM
Deagle's Avatar
wants the ads to die
I've seen a Miata with a Chevy big block so, as everyone will say: Depends on how big your pocket book is. Nothing is impossible.
Old Feb 19, 2004 | 02:15 PM
Guinader's Avatar
quick question, can a VQ30det fit a 4th gen max?
well better yet, what Nissan engines can Fit into a max?
Old Feb 19, 2004 | 02:18 PM
Kevlo911's Avatar
Kevlo for President
You can add turbo, take parts from the VQ30DET. No other engine can "dropped in" woith out major modification.
Old Feb 19, 2004 | 02:52 PM
Tatanko's Avatar
Bacon Lover
So a VQ30DET is pretty much a straight drop-in? That is to say, with minor modification...
Old Feb 19, 2004 | 03:30 PM
vsamoylov
yes, i did it with my bro in our garage
Old Feb 19, 2004 | 03:33 PM
nismos14's Avatar
§è~® f®ÈÄk
u have a vq30det? no, u have a vq30de-k, different story
Old Feb 19, 2004 | 03:47 PM
vsamoylov
never mind i forgot t stands for turbo
Old Feb 19, 2004 | 04:01 PM
Kevlo911's Avatar
Kevlo for President
No, the VQ30DET cannot be dropped in, the people who had the engines took the parts off of it for a reason.
Old Feb 19, 2004 | 05:02 PM
Tatanko's Avatar
Bacon Lover
What all parts BESIDES the bottom-end are used from the DET? Like, is it easy to use the turbo off of it or what not? (Just a theoretical question...) COULD you use the turbo off of it if you wanted to (if you had a somewhat boost-prepped engine)? The DET has a lower compression ratio doesn't it? What makes that different, the headgasket or what?
Better yet...anyone know of a site with lots of DET info on it?
Old Feb 19, 2004 | 06:12 PM
you can use all the internals from the DET like everyone else said, but its not a direct bolt on, im planning on getting a DET motor and a DE motor and then il just take out teh internals from the det and put them in the spare DE and and the port and polish it sence its out and drop it in my max, and them my max motor will be chillin in my garage while i mess with it and see what i can do to that, with some custom heads and stuff like that......... all this i plan on doing would be in the summer time... hope everything goes well, i just need to find that DET JUN manifold people bin talking about and i also need to find out where to get the DET and how much it will cost.
Old Feb 19, 2004 | 06:17 PM
Here ya go
VQ30DET
thanx but im not planning on getting it just yet....therte is this place down here that imports motors from japan so im gonna ask them for the price inclding the DE.
~~sorry bout the double post~~
Old Feb 19, 2004 | 06:23 PM
Flava_24/7's Avatar
Boosted Panda
You sure it was a big block?
Ive seen small block 350's around my area in Miata's. , most popular are Ford 302's .
Old Feb 20, 2004 | 01:15 PM
RyCrisp's Avatar
Take a look at the pics...those engines have mechanical fans on front of the engine where we have electrical fans mounted to our radiators. Those motors are built for mainly rwd vehicles since they should be mounted in the bay front-ward...not sideways like ours are.
Old Feb 20, 2004 | 04:49 PM
nismology's Avatar
Well from what we know, the head is identical to the DE, I.E. cams and valve timing. The pistons are slightly dished in the DET for the 9:1 compression ratio. Also the DET crank has larger rod journals so that means the rods are different also. And IIRC, it has oil squirters that cool the bottom of each piston...
Old Feb 20, 2004 | 05:55 PM
yea im looking for that info also.....im not gonna do the swap if i can't find any info on the motor, screw that, im just get a vq30de and just gut the bia and get a custom stroker kit....
Old Feb 20, 2004 | 08:18 PM
DAVE Sz's Avatar
Hooooooonda.....
Man VSAMAYLOV can't even remember what he put in his car, just makes him look more shady. The DET is RWD so it won't fit directly. Use the pistons but why drop the CR to 9.5:1 or 9.0:1 if you aren't boosted? Other partscan also be used.
Old Feb 20, 2004 | 08:30 PM
yea that's y i was thinking about getting the DET and gutting it for the internals sence im gonna go with a turbo thi summer and cause of the compression ratio.
VQ'ed
69
Aug 27, 2020 12:29 PM
brainiac-dumb
Jul 7, 2003 12:04 PM
Nealoc187
Jun 27, 2003 03:56 PM
Stick Max
Jun 16, 2003 04:28 PM
ejj
Jun 16, 2003 11:22 AM
