Missing ECU screw
Old Feb 25, 2004 | 08:18 AM
WMAJr1980's Avatar
Missing ECU screw
I have a 99 GLE, and my check engine light came on recently, so I thought I would pull the codes from the ECU myself. Problem: There is no screw on the ECU, just a hole with no screw. The sticker on the ECU was fully intact, and had not been punctured. Any ideas?
Old Feb 25, 2004 | 08:30 AM
poly12's Avatar
It is a tiny philips. If you use a mirror behind gas pedal and shine a flashlight in the hole you'll see it.
Be carefull when turning the screw as when I did it, I couldn't feel any stops as the text seems to indicate you should.
I just turned a quarter turn clockwise, wait 2s, turn quarter turn counterclockwise.
Good luck!
Old Feb 25, 2004 | 08:45 AM
billy_corgan's Avatar
yeah be VERY carefull. I wasn't and broke mine off.
Old Feb 27, 2004 | 07:13 PM
jillumjill's Avatar
i think i broke mine too - what is the impact of that?
Old Feb 27, 2004 | 09:50 PM
superblack98se's Avatar
lol me too!
Old Feb 27, 2004 | 10:19 PM
Jepht20's Avatar
Custom User Title...
you guys should go by sound and not feel. you can hear it make that weird buzz noise, then wait two seconds, turn back again to hear it and you should be set. that stinks it's so sensative.
Old Feb 28, 2004 | 04:38 AM
Kevlo911's Avatar
Kevlo for President
You should go to autozone and let them pull the codes, and then convert the codes using hte sticky -"Help my check engine light is on"
Old Feb 28, 2004 | 09:38 AM
nroyle01's Avatar
make sure its the right hole. take computer out and apart and fix it. maybe the switch is floating around inside the comp. if yours broke do the same thing. there is a piece of plastic in switch that you could probably super glue. i did. now i'm careful not to turn screw hard.
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
rbaker100
Sep 25, 2015 07:52 PM
