clutch replacement suggestions
Since the search doesn't work . . .
I need to replace my clutch - what do you guys suggest? JWT? ACT?
Which version of each? I have all the bolt ons on my 2k 5spd. I don't want it to be too brutal but I would like an upgrade over stock.
What about the flywheel? Should I replace also? Will I need to resurface?
Thanks in advance.
Thanks in advance.
Well you're in the 4th gen forum, but either way...
If you're not getting a turbo, nitrous or a supercharger anytime in the near future, I'd stick with a stock replacement. It should hold all the power you'll be making and it won't be as harsh on the tranny as a stronger aftermarket clutch. Just make sure you get the OEM replacement parts, NOT the Key Value package.
CorollaULEV
30
08-09-2021 08:11 PM
