Had a scare today
Old Mar 11, 2004 | 05:10 PM
guido32's Avatar
Had a scare today
I ran some errands today, and when I returned home, I found a puddle of oil under my car, after sitting there for only 10 minutes! I got under the car to see what was happening and there was oil all over the undercarraige. I was ****ed because I was getting my new rims installed today, and didn't need another hassle. I took the car to my mechanic, and was scared to know how much the repair would be. To my dismay, it was the oil pressure sending unit. Total cost: $60 including labor.
Thank god! I got my new rims installed, so the day ended on a good note.
Later guys
Old Mar 11, 2004 | 05:56 PM
RideTheMax's Avatar
Old Mar 11, 2004 | 06:02 PM
Maxima95Tuner
lol. mine just went out about a month ago too. cheap stuff. lets see the rims!
Old Mar 11, 2004 | 06:03 PM
WillMax95's Avatar
yeah, bring on the rims
Old Mar 11, 2004 | 06:05 PM
007max's Avatar
yea, those oil sending units are POS's, oh, and where are the pictures?
Old Mar 11, 2004 | 06:11 PM
Maxima95Tuner
You're stalking me arent you? Following me around post after post!
Old Mar 11, 2004 | 11:20 PM
guido32's Avatar
I am not stalking you Maxima95Tuner. I will get the pics up asap. However, the rims are just 15's. The car came with really great bfg's, and they were almost new. However, the rims on the car were gold and silver! They looked like ****, now the car looks pimp. Give me a couple days to wash/wax it, then I will post pics. Later
Old Mar 11, 2004 | 11:23 PM
FanaticMadMax's Avatar
Wow, that's a good thing it's just the oil sending unit. Otherwise it could have done worse if you haven't noticed.
Old Mar 11, 2004 | 11:24 PM
Jepht20's Avatar
Custom User Title...
i love when you think things are really bad, and then come to find out, cheap and easy to fix.
i got mine replaced for $12 & no labor charge when i was getting my brakes done once.
Old Mar 11, 2004 | 11:29 PM
DAVE Sz's Avatar
Hooooooonda.....
Dude you got ripped off like crazy. Oil pressure sending unit is around $8 and the socket is $5. The job takes about 10 minutes including raising and lowering the car.
Old Mar 12, 2004 | 12:03 AM
GraniteMaxSE's Avatar
On the other hand, don't you just hate it when you aren't sure what to what magnitude certain problems exist, and then come to find out it's a kick in the pants, more specifically, the pocket that carries your wallet?
[(Messed up parts: Oil-soaked clutch, oil-soaked flywheel, bad oil pan gaskets, bad cam plug, bad rear main seal, cracking rear motor mount, screwed up 1-2 synchro assembly, bad transmission mount and a slew of other internal transmission problems.)
Total cost, including labor: $2600
(Yes, I did get ripped off, but the place I had the stuff done with offers the same warranty as factory, does really good work, and it was still hundreds less than the dealer estimate. Even if I knew how to do everything myself, it would still cost me at least 15 hours of my time, and $1000 for parts)]
Old Mar 12, 2004 | 12:09 AM
Nismo's Avatar
mine leaked around 28k
Old Mar 12, 2004 | 11:55 PM
guido32's Avatar
Hey GraniteMaxSE, I don't think you got that ripped off. I bought my car knowing the transmission needed to be rebuilt. After taking it apart, my mechanic found that it needed new syncros, seals, and bearings, and a new clutch. That work was to be around $1500. After examining the car with everything off, he noticed the rear main seal was leaking slightly. If I waited to replace it, and it failed, it would take out the clutch, and possible damage the flywheel but slewing oil over them. In turn, those parts would not be covered under the warranty since the clutch/flywheel didn't fail by themselves.
Therefore it was a no-brainer to replace the seal to save future repairs and unnecessary costs. So I had him replace the rear main seal. What sucks about replacing it is that the oil pan needs to be removed, because it blocks part of the seal. You cannot just bend it out of the way because nissan (in its glorious effort of over-enginnering) made the pan out of forged aluminum instead of just regular aluminum. To remove the oil pan, you have to remove a crossmember, the air cond. compressor, the alternator, and some other parts. Long story short, its labor intensive. So my total bill was $2000. Anyway, your $2600 is more than mine, but they may have replaced more parts.
Old Mar 13, 2004 | 12:17 AM
eturnl
I dont mean to sound ignorant, but what is a rear main seal? i have been asking this question forever.... but no answer, can someone clear this up and how do i know if mine is bad? pics would help! thanks fellas.
howardis
Dec 11, 2019 06:10 PM
Forge277
Jun 13, 2016 09:26 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
