Just installed Vibrant FSTB
Old Mar 16, 2001 | 08:32 PM
Nathan's Avatar
Today I went to a local rental shop and was looking for a torque wrench. The guy at the rental shop wanted $15 Canadian for 1 days use. I then went to Sears and bought one for $25 and a 19mm bit for $8. Luckily, just before I left Sears I checked to make sure the bit would fit on the bolts. To my surprise it didn't so I returned it and got a 23mm which fit but was a little loose. Does anyone know the exact size of the bolt for a '99 Maxima? I've already installed the FSTB but I'm going to return the bit tommorrow. I'll be posting up some pics of the bracket that I cutt off and the FSTB.
Old Mar 17, 2001 | 09:10 AM
Daniel B. Martin's Avatar
22mm or 7/8-inch
Those big acorn nuts on the '99 are 22mm. You will also find that a 7/8-inch socket is a perfect fit.
Old Mar 17, 2001 | 09:17 AM
ezemax99se's Avatar
Re: 22mm or 7/8-inch
Nathan said he had to cut a bracket. I don't recall you saying that did any cutting, only that you had to replace the acorn nut with regular hex nuts. Is it just the vibrant bar that is different from the courtesy?
Old Mar 17, 2001 | 01:39 PM
That annoying bracket
I have no information about the Vibrant bar. I installed the Courtesy bar in a '99 and the end plate had a notch which cleared that annoying bracket.
Old Mar 18, 2001 | 07:29 AM
Nathan's Avatar
Re: Re: 22mm or 7/8-inch
ezemax, the Vibrant FSTB doesn't have a notch like the Courtesy FSTB so if you have a '99 max you have to cutt of the bracket on the driver side strut tower. The bracket blocks the end bracket from sitting on the strut tower. However, with the Vibrant FSTB you don't have to worry about the acorn nuts brocking the bolt for the end bracket. The reason why I bought the Vibrant over the Courtesy is that it costed me only $50 Canadian without shipping, whereas the Courtesy bar would cost me $70US plus shipping and duties. And as everyone knows the value of our dollar compared to the US is almost half.
Old Mar 18, 2001 | 09:01 AM
ezemax99se's Avatar
Re: Re: Re: 22mm or 7/8-inch
Thanks for the info Nathan. I just ordered the vibrant from Streetbeat yesterday. It should be here by the end of the week. Did you get much more pickup after installing the Ractive intake? I plan on going with the JWT cone intake. Also, how is the FSTB working out? Can you tell much difference? Thanks.
Old Mar 18, 2001 | 10:36 AM
costcowholesale's Avatar
where is streetbeat in canada?
Old Mar 18, 2001 | 10:57 AM
mAdD MAX's Avatar
costcowholesale:: there's a store on Kennedy/Lawrence called Performance Improvements that sells the Vibrant FSTB for $50CDN.
Old Mar 18, 2001 | 11:02 AM
so I'll need a torque wrench and a saw to cut the bracket off? what about rear antiroll bars can I get them there?
Old Mar 18, 2001 | 07:02 PM
Nathan's Avatar
Re: Re: Re: Re: 22mm or 7/8-inch
ezemax, I actually bought the Ractive intake because it would save me money because Nissan charges quite a lot for there replacement filters which are very restrictive. After I installed it, I found a very slight change in performance. The biggest improvement is at higher rpm's, however if I had the extra money to spend I would definetly buy the JWT pop charger. My biggest surprise from the Ractive intake was the increase in noise at takeoff which is pretty neat.
Yesturday my dad and I were on the highway and we were going a little over 110km/h on a highway onramp and there was a noticable difference in handling. At normal speeds you won't even know the FSTB is there.
Old Mar 18, 2001 | 07:07 PM
Nathan's Avatar
Costco, go to Sears and by one of there Craftsman torque wrenchs and a bit for the nuts. The torque wrench's are $24-$26 and the bits are aroung $8. I tried local rent all places around T.O. and they charge around $15 to rent a torque wrench for 1 day.
Old Mar 18, 2001 | 07:09 PM
do I need to cut that thing out sticking up on the drivers side tower?(I have a 99) if yes how did you cut yours?
Old Mar 18, 2001 | 07:55 PM
Nathan's Avatar
Costco, if you buy the Vibrant FSTB you will have to cutt off the bracket on the strut tower. I used a hacksaw. It was actually pretty easy. After you hacksaw it off, use some primer and them some touch up paint. Go to this link for lots of good info: http://www.chrislehr.com/maxima/fstb.html
Old Mar 19, 2001 | 01:04 PM
BlkCat
Geez! I should have gotten you to order one for me if I knew that, Nathan! I ordered a Vibrant bar back in August and gave up waiting after 3 months! How long did you wait for yours? I ended up ordering the Courtesy one from Texas and got it in a couple of days! Because mine's a '98 I didn't have to cut anything off on the strut towers.
Old Mar 20, 2001 | 07:53 AM
Re: That annoying bracket
So, I've gathered this bracket is only on '99s. I have a '98SE and already ordered the Vibrant from SB, and wanted to make sure I wasn't going to run into this problem.
Hal
Old Mar 20, 2001 | 08:20 AM
breaux124's Avatar
You can usually go to a local autoparts store and they let you borrow parts for free, you just have to put a downpayment.
I did this when I needed a torque wrench. $20 down and I got it back when I returned it.
Old Mar 20, 2001 | 10:12 AM
Re: Re: That annoying bracket
Hal
'99-up have that bracket, but this is the 4Gen Maxima forum so we can say only '99s.
Old Mar 20, 2001 | 10:56 AM
focker2889's Avatar
Re: Re: Re: That annoying bracket
lol!
for those who want to saw off that bracket, it is easier to do so with a dremel kit. Just shave that piece of metal off your mount.
to avoid the headache, I recommend the Stillen FSTB.
......we can say only '99s.
Old Mar 20, 2001 | 06:02 PM
Nathan's Avatar
Re: Re: Re: Re: That annoying bracket
Originally posted by focker2889
lol!
That's if you had enough money to spend on such a minor mod. I personally don't think there would be much better improvement in handing over the hollow bars especially considering the price of the Stiilen FSTB.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
