Cruise Control Problem
Old Apr 8, 2004 | 03:12 PM
krue92's Avatar
I have a 95 SE 5-speed and my cruise control hardly ever works. I can turn the button on and it will light up, but when I try and hit the cruise on the steering wheel, nothing happens. It will work every once in a great while. Is there anything specific I can check. Thanks.
Old Apr 8, 2004 | 07:47 PM
BadKarma99-4spd's Avatar
does it blink when you hit the set button?
mine did that and they told me i needed a new "cruise computer", it worked for six months or so and now its doing it again.
good luck
Old Apr 8, 2004 | 08:03 PM
krue92's Avatar
Mine doesn't blink. It just doesn't work all the time. What components are there to the cruise control.
Old Apr 8, 2004 | 08:27 PM
mansurxk's Avatar
bump.........
Old Apr 8, 2004 | 10:08 PM
MrPink's Avatar
im not sure about the maxima but most cars cruise control works by applying vaccum to a vacuum motor that is attached to the second throttle cable thats attached to the throttle body. To control the vacuum motor there are two valves, one to apply vacuum (normally closed valve)and one to release vacuum (normaly open valve).Try to check the operation of all of these components and check all the vacuum lines that are attached to them. I hope this helps
Old Apr 9, 2004 | 04:58 AM
nupe500's Avatar
Jedi Knight
It could also be related to your clockspring not being connected properly...does your horn work?
Old Apr 9, 2004 | 07:00 AM
Jepht20's Avatar
Custom User Title...
would speed sensor be something to check also? have you checked for codes?
Old Apr 9, 2004 | 07:39 AM
krue92's Avatar
Horn works. I am also throwing no codes.
Old Apr 9, 2004 | 07:42 AM
Jepht20's Avatar
did you check or are you just saying that cuz the light isn't on? i've had codes before that didn't set off the cel...
Old Apr 9, 2004 | 07:49 AM
krue92's Avatar
Well I had a fuel injector code a while back and when I fixed it, I checked it after that and had no codes. I haven't checked in the last month or two though. Do you do it the same way you would when you are getting a light?
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
slowlifer
Sep 8, 2015 05:53 AM
