Ecu Code Translation 0307 + 0509
Old Apr 14, 2004 | 07:48 AM
nkumke's Avatar
This Dam Check Engine Light Keeps Popping Up. Retrieved Codes And Recieved 0307 Closed Loop Connection, And 0509 Which Is Undefined. The Throtle Response Seems To Be Slow And Feels Like It Is Stressing To Get Air. 96 Max W/ Cai. Help Anyone
Old Apr 14, 2004 | 08:21 AM
Kevlo911's Avatar
Kevlo for President
0307
Diagnostic Trouble Code 0307 points to a problem with the Engine Control Module Closed Loop Logic for the Left Bank. The left cylinder bank is also called the front bank. It is cylinders 2,4,6.
DTC 0307 is detected when the closed loop control function for the left bank does not operate even when the vehicle conditions meet the criteria (engine at normal operating temperature, etc.). Possible causes include ...
- Harness or connectors (The sensor circuit is open or shorted.)
- a defective Front Heated Oxygen Sensor sensing element.
- a defective Front Heated Oxygen Sensor heater.
Old Apr 14, 2004 | 08:47 AM
nkumke's Avatar
Could It Be A Promblem With The Plugs? Or With The Ks? Those Are The Only 2 Repairs I Have Messed With. Or Is It Just That I Need A New Front O2 Sensor.
Old Apr 14, 2004 | 08:55 AM
Kevlo911's Avatar
Kevlo for President
I would say you need a new O2 sensor.
Old Apr 14, 2004 | 08:58 AM
nkumke's Avatar
Is There Any Way To Check The O2 Sensor To Test It? That Is The Raditor Side? Does It Matter If It Is A Bosch Replacement Or Should I Go With Denso Or Ntk(ngk)? Where Is It?
Old Apr 14, 2004 | 08:59 AM
nkumke's Avatar
103k All Orginal, All Stock
Old Apr 14, 2004 | 09:04 AM
Kevlo911's Avatar
Kevlo for President
O2 sensor in the front, you can buy one from www.buyoxygensensors.com
Old Apr 14, 2004 | 09:13 AM
nkumke's Avatar
Thanks For Your Help.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
