rear wheel noise
Old Mar 22, 2001 | 10:49 AM
ibusticon's Avatar
HELP, I have a 97SE Auto that I just purcahsed, Luckily the powertrain is still covered. However, I am noticing a squek in the driver side rear wheel when in reverse only. Please Help with Diagnoses, i hate to think its a bad Rotor already...But the squel has the distinct high pitched whine similiar to the one i had when i owned my Sentra and it needed brake work
Old Mar 22, 2001 | 11:35 AM
Daniel B. Martin's Avatar
The likely causes of this squeak are a bad wheel bearing or trouble with the brake. Jack that wheel and spin it. A bad bearing will make small grinding or grumbling sounds. A brake problem will make a scraping or squeaking. Pull the wheel and inspect the brake pads. Your problem may be nothing more than worn-out pads. This diagnostic inspection will take only five minutes.
You said "the powertrain is still covered." I don't believe brakes are considered part of the powertrain.
Old Mar 22, 2001 | 11:49 AM
ibusticon's Avatar
thanks
for the friendly advice. yup i know brakes aren't covered under the powertrain, i guess i was just giving myself piece of mind if anything in the future happens within what is covered under the 60k warranty, i still have about 13k left. If it is a bearing situation am I looking at a costly repair?
Old Mar 22, 2001 | 12:04 PM
$100(?)
... If it is a bearing situation am I looking at a costly repair?
No. My guess is the problem is worn-out brakes. That's not expensive either. Either way, expect to pay somewhere around $100. This repair does not have to be done by a dealer.
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
Huttig2009
Sep 25, 2015 03:31 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
