just got back from the dyno 186HP/194TQ
modz
injen intake
wapeed y pipe
greddy sp cat-back
test pipe
udp
fidanza flywheel
www.ri-sho.com/zJeff-S.jpg
BTW i have 166,000 miles on here and i ran a 14.9 w/o the flywheel.
is it just casue i cann't drive?????? or are those number low???
injen intake
wapeed y pipe
greddy sp cat-back
test pipe
udp
fidanza flywheel
Originally Posted by Big D
Yes, same thing. Takes away TQ and makes your exhaust raspy as fudge.
the test pipe takes away some TQ?? really... i just hate the bee noise i get. other then that i like it
what kinda power u think i'll be puting down when i get the JWT ECU 7200/MEVI
zack342.. i wish i had a 99 SEL lol but i do have the SEL floor mats in my SE
lol
lol
just the fact that all the exhaust is being forced through a 6 foot pipe and a muffler will make some backpressure.
for example: a 70s straight pipe v8 trans am will be faster if you add a cat? NO
id say to get a test pipe if your cat is going bad, test pipe is about $20, a oem cat is what, almost $200?
Add a balance pipe to your T/A= More power, it will equalize the flow between banks. And you are right, adding a cat won't do anything for it. What I wasn trying to get at was that a test pipe on a max with a full system maybe a little to free flowing. Putting a Cat back on may help restore some low-end torque.
Originally Posted by FNG
Easy, a little back pressure is alway's good. It helps build torque. Dyno test's(mostly on V8's) have consistently shown that a full exhaust with a little back pressure will produce more power than an open exhaust.
"Exhaust system backpressure is ALWAYS BAD! Engines do not need backpressure to make good torque. What an engine needs is a system that maintains high exhaust stream velocity at low RPM.
Read http://www.magnaflow.com/05news/magazine/05sportc.htm for a good explanation."
In the 4th gen modification FAQ's, post 33
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
