Camber
Old May 9, 2004 | 01:06 PM
XeroX's Avatar
Hella internets
Camber
I am gona lower my car about 2 inches on Ground Controls... from what i have heard, the camber will be off about 2 degrees, wich i DONT want... i want it to be perfect...
Where can i get Camber plates for cheap...OTHER than the 400 dollar stillen ones.. are there other places i can get em?
I have also heard about camber bolts...but i have heard that they come loose after a while.. is this tru? should i get the camber bolts or the plates? if so what brand bolts should i get? i was thinking about Ingalls...
Old May 9, 2004 | 01:18 PM
97SEMAXI's Avatar
check ebay, or swa......
Old May 9, 2004 | 01:39 PM
XeroX's Avatar
Hella internets
alright kewl...
any more opinions?
Old May 9, 2004 | 01:42 PM
97SEMAXI's Avatar
dont know how you feel about buying stuff on ebay, but i just looked and you can get a front camber kit for like $25 plus shipping which is like $15, so $40 aint too bad, a lot better than $400
Old May 9, 2004 | 02:01 PM
gtr_rider's Avatar
192.168.1.1
Ive had the camber bolts for a month now, they are doing just fine
Old May 9, 2004 | 02:51 PM
XeroX's Avatar
Hella internets
what kinda camber bolts? Eibach or Ingalls? or something else..
as for the Ebay...is this for Camber Plates? or camber bolts? cause that sounds a lil too cheap for camber plates...
Old May 9, 2004 | 05:07 PM
gtr_rider's Avatar
192.168.1.1
I used the Eibach camber bolts, 1.75 degree of play +/-
Old May 9, 2004 | 05:15 PM
XeroX's Avatar
Hella internets
how low did you go? im goin 2 inches...
Old May 9, 2004 | 05:25 PM
SpeedCrazie's Avatar
Does anyone have a how to install? It should seem straight forward but I purchased the ingalls kit and it has a plate of some sort on it?
Thanks.
JP
Old May 9, 2004 | 05:47 PM
gtr_rider's Avatar
192.168.1.1
Somewhere between 1.5-1.8, drop is unknown with these Tokico Springs.
Old May 9, 2004 | 05:48 PM
gtr_rider's Avatar
192.168.1.1
Thanks.
JP
They SHOULD come with instructions, I know the eibachs did. They are easy to install, but you should get your alignment done right away so they can adjust them properly.
Old May 9, 2004 | 07:49 PM
Oblongshapes's Avatar
where did you get your eibachs at... i need some, im off 1 degree and im putting AGX's on this weekend, so might as well put these in too
Old May 14, 2004 | 08:53 AM
XeroX's Avatar
Hella internets
SWA sells the Eibach ones...
matts95max
Apr 23, 2025 10:44 AM
Dan93se
Apr 7, 2001 02:46 PM
sachin98max
Feb 24, 2001 11:35 PM
I30CeFiRo
Dec 28, 2000 09:25 PM
ZuMBLe
Nov 1, 2000 07:39 PM
