Injen install?
Old May 12, 2004 | 04:32 PM
Sqard's Avatar
Injen install?
Just got the injen intake in the mail today. I've installed a frankencar intake before, thought it'd be a piece of cake. Took the stock intake off, ended up breaking the MAF sensor in the process by dropping it. Can't believe this is a 450 dollar part. I decided to glue it back together and continue with the install. Followed the directions, they said to plug the air sensor from the stock airbox into the upper pipe. I don't have any sensors in my stock airbox to begin with. What are they referring to here? A pic would be awesome
Old May 12, 2004 | 07:28 PM
96maxdaddy's Avatar
keep looking, I have a 96 so mine was bolted to the air box and looks like a small resistor. I believe on 98s the airtemp sensor just looks like a long plug. It sould be on the box or in the hose that goes to the throttle body.
Old May 15, 2004 | 07:45 AM
Sqard's Avatar
Can someone show me a pic or a writeup of this?
Old May 21, 2004 | 05:14 PM
Sqard's Avatar
bump....can anyone please tell me where this sensor is located?
Old May 21, 2004 | 05:46 PM
Magikone69's Avatar
my air temp sensor was located inside the stock airbox as well, look around. also the total wire for the sensor was all sealed together with the harness for the MAF so it houldnt be too far from there. that sensor isnt really needed anyway so if you cant find it im sure you can survive. i just have my sensor dangling next to where the stock airbox used to be, noticed no difference.
Old May 21, 2004 | 05:57 PM
Conrad283's Avatar
I need a truck
Which intake did you get? The 1925 or the 1930? The 1925 is made for the 95-96 maximas that have a air temp sensor which goes into the elbow of the intake right before it reaches the throttle body. If you have the 1930 (which you should because you have a 98) Then there should be no place for it since you do not have the air sensor. I'm finishing up my philosophy paper right now, but I'll go snap a pic in a little while. Hope this helps for now.
Old May 21, 2004 | 06:01 PM
Sqard's Avatar
I have the 1925.....on the box it says 6/94-6/98 and my build date is 5/98 so thats what I ordered. I've taken the stock air box off 3 times already and looked around and still don't see what they have in the picture.
Old May 21, 2004 | 06:03 PM
Conrad283's Avatar
I need a truck
Gimme a little while and I'll go snap a pic because I know exactly what you're trying to find.
Old May 21, 2004 | 06:07 PM
ScarfaceTHX's Avatar
Sounds like a job for duct tape!
Either that or send it back and order a new one with less holes. RTFM j/k
Old May 21, 2004 | 07:13 PM
Conrad283's Avatar
I need a truck
Sensor going into the elbow:
Close up of the elbow:
And here's where it came from outta the stock intake:
Hope this helps
Old May 21, 2004 | 09:15 PM
VIP Maxima
for 98's. there is no sensor in elbow, its a tiny small sensor that u'll see once u take stock airbox out. its near maf sensor and its pluged into one of the pipes that goes from the front above radiator all the way back. once u take this off, ull see it plugged in the pipe.
insert the sensor in the hole in the smaller piece of the injen intake pipe...
Old May 21, 2004 | 09:24 PM
VIP Maxima
Hope this helps
completly ignore this post sqard.
no offense, very true information but only applies to 95-96
Old May 22, 2004 | 03:41 AM
Conrad283's Avatar
I need a truck
No offense taken, but buddy if you read the whole post he says that he got the 1925 which is for the 95-96's but injen gave these weird production dates.
He's looking for the sensor which he obviously doesn't have. He said he looked through the intake 3 times looking for the sensor. I snapped the pics to show what the sensor looks like and where it came from.
No offense
Old May 22, 2004 | 04:11 AM
sagamax's Avatar
Give me a Bud Light Holmes
black tape and zip ties are my favorite tools. they can work miracles
Old May 22, 2004 | 12:26 PM
VIP Maxima
No offense
my bad, all is saw was 98 under his name so i assumed he got the right one.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
