First time changing oil in used Max 98 How many quarts?
Old May 16, 2004 | 12:38 PM
jeostang's Avatar
I checked the how to guide and it said 3 liters. Doesn't that come to about 3.5 quarts? I just put in 4.
Old May 16, 2004 | 12:40 PM
Kevlo911's Avatar
Kevlo for President
4.25 with filter. 4 w/o filter.
Old May 16, 2004 | 12:46 PM
jeostang's Avatar
Thanks!!!
Old May 17, 2004 | 09:36 AM
Brudaddy's Avatar
+1
What he said.
Old May 17, 2004 | 03:15 PM
BOSS
that's weird. Whenever I change my oil and let everything drain out completely, it honestly takes exactly 3.3-3.5 quarts for the scale to read "half full" the next day when it sits over night (because that's how one obtains the most accurate reading from what I know). And yes, I do change the filter every time.
Old May 17, 2004 | 03:29 PM
Kevlo911's Avatar
Kevlo for President
Interesting. So that means your car is always using old oil. CHekc hte color of the oil when you put it in. Let hte car warm up, then let it cool down and see if hte color is hte same.
Old May 17, 2004 | 03:39 PM
BOSS
Just in case you didn't read my previous post in full -
I said that I drain my old oil completely. I take off the old filter and then I let the car sit there for a good hour or two before I fill it with the new oil. Then I put in exactly anywhere from 3.3 to 3.5 quarts of new oil, start the car up, and drive around a bit.
The next morning, I check the oil. It reads precisely "half way". I don't understand how you guys put in 4.25 quarts?????????
I swear, if I go even slightly over 3.5 quarts, then it points to either "full" or beyond that, which is bad.
....and no Kevlo, the oil looks fresh and clean the next day
Old May 17, 2004 | 03:48 PM
DAVE Sz's Avatar
Hooooooonda.....
Do you tilt the car to the left? Whenever I change my oil I put the jack on the driver's side of the car so that the oil seeps out completely. Wait 10-20 minutes and everytime I get 4.25 quarts out.
Old May 17, 2004 | 03:52 PM
Frank Fontaine's Avatar
I put 4 1/4 quarts last time to a "t." The next day when I checked the oil it was over the full line, by about 1/2 the range. Next time I will put only 4. I know everyone always cautions about overfilling, but I think I'm ok. Just think about how much 8 oz. of fluid is, nothing. I'm not even convinced the VQ dipstick is accurate, as it's not perfectly straight.
Old May 17, 2004 | 05:02 PM
davey6693's Avatar
Yep 4 litres up here in Canada, which = 4.23 quarts and its always on the money.
Old May 17, 2004 | 05:04 PM
Capital15's Avatar
Four here.
Old May 17, 2004 | 05:08 PM
happyricefob's Avatar
V^___^V
according to the owner's manual:
4 5/8 quartz with oil filter. i recommend mobil 1 supersyn synthetic 5w/30 + OEM nissan filter. don't use fram filter cuz they don't filter good and they suck.
MatthewsMaxima
Sep 11, 2015 03:21 AM
Maxgig
Aug 18, 2015 09:17 PM
Balkins
Aug 12, 2015 06:39 AM
RealityCheck
Aug 5, 2015 06:18 AM
