HELP! Can't go over 30mph!
Old May 16, 2004 | 02:05 PM
PmpLuxCEO's Avatar
Alright, so after I got my new engine swapped back in I finally decided to take it out for a test run. . . BUT! The car won't go past 30mph. . When looking at the RPMs, I will hit 1800 rpm and then the engine sounds like its cutting off my fuel or something. I step on the gas, but it's as if I hit the rev limiter? Does that make sense? HELP?! What is wrong with my car?!!!!!
Old May 16, 2004 | 02:37 PM
Kevlo911's Avatar
Kevlo for President
Make sure the MAF sensor is plugged in and working.
Old May 16, 2004 | 05:36 PM
QuikSilver71's Avatar
wanna race?.
Hope you get this sorted
Old May 16, 2004 | 05:38 PM
image's Avatar
Yep gotta be the mass air flow sensor. Plug that bish back in.
DAVE Sz's Avatar
Hooooooonda.....
There is a clamp or something stopping your throttle assembly from going WOT. See if you can open the butterfly inside the TB all the way.
Old May 17, 2004 | 06:42 PM
PmpLuxCEO's Avatar
ok thanks, I'll try to check out the MAF tonight. Although, I coulda sworn I plugged it in. . .
Old May 17, 2004 | 11:05 PM
PmpLuxCEO's Avatar
OK guys. . .
1. Butterfly inside TB opens all the way. .no hindrence.
2. MAF plugged. THere are no CEL or codes when starting the car.
Anything else?! HELP!!!!!!
Old May 18, 2004 | 03:42 AM
sryth's Avatar
Does it bounce at 1800RPM? You know, like at the rev limiter.
Old May 18, 2004 | 08:09 AM
njmodi's Avatar
Do I get a tax break?
Doesn't the car do this when it is in limp mode? I don't remember how to determine if it is in limp mode or how to get out of it - maybe its in the FAQs or how-tos?
Nirav
Old May 18, 2004 | 08:54 AM
2naboy's Avatar
I had this exact problem I had totake it to a professional and he got it running. He said something about a choke mechanism by where the throtle cable is at. I will try to go down to that shop and find out exactly what he did.
Old May 18, 2004 | 09:52 AM
PmpLuxCEO's Avatar
Thanks for the help in advance. .. .
1. I don't know what limp mode is. can anybody elaborate?
2. Yes the rev bounces at 1800 . . . it goes up to 2000 then drops back to 1500...
Old May 18, 2004 | 01:22 PM
Kevlo911's Avatar
Kevlo for President
Reset hte ECU and see what happens.
Old May 18, 2004 | 03:12 PM
DAVE Sz's Avatar
Hooooooonda.....
Maybe the TPS is set up wrong? If lets say it was tilted all the way to one side, wouldn't it cause a low voltage reading and limit the rpms?
Old May 20, 2004 | 06:47 PM
PmpLuxCEO's Avatar
OK, reset the ECU, got a 0505 A-OK all clear,nothing wrong. . .
TPS? IS that Throttle position Sensor?
I dunno, but i dropped the car back off to my mechanic and I guess we'll see what's up. Also discovered that my car is blowing out smoke through the exhaust. Perhaps I'm running too rich? Dunno cuz my SAFC is not installed yet.
Old May 20, 2004 | 07:41 PM
njmodi's Avatar
TPS = throttle position sensor.
Old May 20, 2004 | 10:06 PM
DAVE Sz's Avatar
Hooooooonda.....
To check the TPS, open the TB butterfly plate all the way and disconnect the BROWN connector on top of the TPS. Now using a multimeter check if you have around 4v between pin 1 and 2 on the TPS not the brown connector.
Old May 20, 2004 | 11:44 PM
808_Pimpn_max's Avatar
Hey Will,
Still not up and running right yet?! Maybe I'll come drop by, let me know when you are free.
Jonathan
Old Jun 29, 2011 | 12:48 PM
viking1's Avatar
I have this same problem after running sea foam thru engine. TPS replaced twice, as is knock sensor. Disconnect the TPS, and car runs normal but idles high (110 in neutral; 1800 in any gear). Any ideas?
Old Jun 29, 2011 | 12:49 PM
viking1's Avatar
"1100 in neutral", sorry
Old Jun 29, 2011 | 12:53 PM
Bufflomike's Avatar
Sexier Than Simpson
I would do the idle relearn and ECU reset but it sounds like you may have did the dreaded Throttle Plate touch. Check the stickies for these procedures.
Old Jun 29, 2011 | 12:54 PM
cashoit's Avatar
First off, did u calibrate and install TPS properly.
Second, if u are idling high like that, clean ur TB and MAF. Check your IACV.
Old Jun 29, 2011 | 08:26 PM
viking1's Avatar
What is bizarre is that the car idles normally with the TPS plugged in, but wont rev past 1800 rpm. If I UNPLUG the TPS, it idles at 1800 RPM, but revs up and drives normally (besides the fast idle). Stop the car and throw it in neutral, and it idles back at 1100. Throw it in gear (still stopped) and it pops back up to 1800. I DID clean the IAVC (was severely carboned), but no effect.....
Old Jun 29, 2011 | 08:27 PM
viking1's Avatar
BTW; used MAF cleaner on sensor, and TB is clean....
Old Jun 29, 2011 | 08:29 PM
viking1's Avatar
Assuming idle relearn is disconnecting battery, reconnecting, then turn ignition on and depress throttle 5 times? If so, I tried it w no change.
Stickies? :-)
Old Jun 29, 2011 | 08:58 PM
colombianmaxima's Avatar
well atleast your car runs lol mine doesnt
Old Jun 29, 2011 | 09:26 PM
viking1's Avatar
LOL!!! Between the two of them, we have a perfectly running car.....:-)
Old Jun 30, 2011 | 02:34 AM
Leo_Koneval's Avatar
It doesn't sound like a MAF issue because when my MAF when out I had a bunch of codes, too lean, too rich, bank one, bank two. Basically a mess.
And my car wouldn't run pass 3K RPM.
But your problem doesn't sound like something is physically stopping your throttle but more like a safeguard or something stopping it. Perhaps the TPS is on its way out? Like when you step on the gas its only reading a certain voltage and staying there instead of increasing as you step harder on the pedal.
EDIT: Whoa, I completely thought that viking1 was the OP since you guys had such similar problems! After some more thinking it still puzzles me. Since what ever is stopping the car from going over 1.8K RPM is cutting off fuel or air, but not too sure if it affects spark. And the only things that do that are sensors or maybe its actual injectors themselves not spraying enough gas to go over 1.8K RPM. Could the ECU screw affect or limit our RPM? Maybe its not turned all the way to one side or something.
Old Jun 30, 2011 | 07:50 AM
cashoit's Avatar
Have u checked reesistance for IACV?
PCV?
no leaks in intake piping. U prolly have a crapped out MAF man.
Old Jun 30, 2011 | 09:06 AM
mbxrb's Avatar
I'm having the same problem,my car at fist would bog down after 2000 rpm's.Now after a few days it dies when I give it gas.Many have said it might be the MAF?I hope it is,I just ordered one.(Sorry for the high jack)
Old Jun 30, 2011 | 04:26 PM
viking1's Avatar
PCV?
Is there a specific test for the MAF? I guess I could use the search function (LOL). I DID clean the MAF sensor with proper MAF cleaner. Is there something else besides the sensor that goes out? Didnt change a thing on the ECU.....
Old Jun 30, 2011 | 04:44 PM
viking1's Avatar
TPS replaced twice Leo. Never messed with the ECU.....
Old Jul 2, 2011 | 07:41 PM
sjtech's Avatar
although its very unlikely, if somthing is restricting the exhaust or intake manifold, this could also cause a very low rev ceiling. was this a drop in, a used engine, a short block, or long block?
Hondarydr
Dec 30, 2024 06:15 PM
Daniel
32
Apr 19, 2004 01:22 AM
vivekshar
Mar 17, 2004 09:28 AM
Mmmaxx
Mar 14, 2004 07:58 PM
Craig Mack
Sep 13, 2002 12:33 PM
