Engine noise, please help
Old May 18, 2004 | 07:13 AM
ibrahimekawi's Avatar
Anybody know how to get rid of the squeeling noise on my engine? I changed my belt and it is still there....i think it might be on of the bearings that the belt goes around but im not sure....i think this is a problem with some maxima, cause a friend of mine is got a 1999 I30 and he's got the same problem...anyways if anybody can help please let me know
Old May 18, 2004 | 07:35 AM
njmodi's Avatar
Do I get a tax break?
It is nearly impossible to determine the cause of squeaking with your description.
Does the problem happen only when you are driving?
Does it happen with the A/C on/off?
Did you tighten your belts to the correct tension when you replaced them?
Old May 18, 2004 | 07:40 AM
for sure it's from the belt mechanism
The noise is deffinetly coming from the belt mechanism....u can hear it when ur idling and when ur driving at slow speeds....but i goes away once the car speeds up....and yes the belts are tightened!!!
Old May 19, 2004 | 01:30 PM
nobody else has this problem
no one else has this problem?
Old May 19, 2004 | 01:55 PM
mansurxk's Avatar
they squeal if theyre too tight, or too loose, from what i hear you should adjust the belt a month after because it gets a little more slack so you retighten, see if that helps you, if it doenst, loosen it and see if the it still squeals
Old May 19, 2004 | 11:09 PM
maximus_pr's Avatar
ok take tensioner out and verify that is running smooth if not replace it also check alternator when its bad tends to make whining noise
Old May 20, 2004 | 05:12 AM
97WhtSE's Avatar
I have the same problem with mine. But i always ignored. Now that i think about it i think its just too loose.
Old May 20, 2004 | 09:40 PM
sounds good
I just changed my belt about a week ago and i think the noise is going away....but i think ur right it looks like its going away...i turned my car on today and i didn't hear it too bad today...thnx for the help...and i think if it does keep making noise it probably just needs adjusting
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
