Cruise control problem
Old Jun 10, 2004 | 01:22 PM
vnglonty's Avatar
Please, share you experience!
Cruise control doesn’t work. I switch it on with the switch on the dashboard (it turns green), but when I push the button on the steering wheal, the sign ‘cruise’ on the gadget panel starts blinking and, of course, car doesn’t ‘cruise’.
I checked the vacuum pump (on the driver side of firewall) – put 12v on the contacts. Sounds like working. Also put 12v on the valve (there 2 of them – ‘open’ – no effect, ‘close’ – works somehow) – throttle opened just a little bit. Applied vacuum (from the tire compressor) to the diaphragm - throttle opened completely.
What does it mean? What else could be done? Can I check signals from computer? What should these signals look like (pulses, but …)?
Appreciate your advice, VG.
Old Jun 10, 2004 | 02:55 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
my cruis control does not work because the switch under the clutch pedal is deactivated because of my remote starter...just something to look into if your on stick.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
slowlifer
Sep 8, 2015 05:53 AM
