SEL due to 06-04 code, but not coil problem
Old Jun 13, 2004 | 07:25 AM
ramccombs's Avatar
I have a 1999 Maxima GLE with about 106,000 miles on it. I just received a SEL light and the car runs rough at low idle or accelerating. I thought it might be a bad coil, but I moved the suspect coil from cylinder 5 to cylinder 3 and received the same code from the ECU. I'm pretty sure I reset the ECU correctly by turning the screw clockwise to stop waited a few seconds returned counter-clockwise to stop then repeated the step. I then started the car, which seemed to run and drive pretty smooth, but SEL light was still on. I checked the ECU output again and received the same lights 06-04 , meaning problems with cylinder 5. I just replaced the spark plugs with Bosch platinum +2. Any ideas where to go next? I know there is a possibility that a new spark plug could be bad, but that should be slim.
Thanks for any advice,
Robert
'99 Maxima GLE
Old Jun 13, 2004 | 07:33 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
your injector is screwed. contact me if u want to buy one. ive got some for $45 shipped. they have 25,000 kms on it. and by the way. take thoes spark plugs out and put some ngk coppers in.
Old Jun 13, 2004 | 07:58 AM
Kevlo911's Avatar
Kevlo for President
Put some NGK's in there and hopefully it will be fixed.
The copper plugs are very cheap at autopart stores. Never put anything else then NGK spark plugs in the maxima.
Old Jun 13, 2004 | 09:10 AM
vipervadim's Avatar
I like Maximas
check the connection to the coil pack. mine was loosely plugged in even though it felt alright, wiggle the connector as the car is idling and see if it changes anything. i also though my injector was bad, but it wasn't just the plug connection was off.
Old Jun 13, 2004 | 09:13 AM
I30tMikeD's Avatar
I would try driving a few miles with the coil packs switched. It may take a little bit of time for the ECU to throw a new code.
If you don't get a code for cylinder #3 then try checking the resistance of the injector for #5.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
