MAF Snesor Code HELP!!!!
Old Jun 17, 2004 | 05:41 PM
manitobagle's Avatar
I need some advice regarding the code 0102. I know it is the MAF sensor acting up. Nissan in Canada wants $600 for a new sensor. Is there anything I can do to extend the life of the sensor. Has anyone tried cleaning there MAF??? nay help would be appreciated
Regards
PGR
Old Jun 17, 2004 | 05:48 PM
CUSEMAX's Avatar
i dont know how to fix it, but i have an extra one if you need ill sell it to you... if you dont want to wait though, go to the local junk yard and pick one up. i thought mine had gone bad, so i switched it out, but it didnt end up being the problem (bad coil packs) so i switched back.
Old Jun 18, 2004 | 04:49 AM
Kevlo911's Avatar
Kevlo for President
First find the ground wire on the harness. I forgot what color it was. You need to splice into it as close as you can get and then run a wire to another ground point. Reset the ECU and see if it works. Also, you clean the MAF sensor element, you need to put rubbing alcahol on it, sometimes hte element gets dirty.
TallTom
57
Oct 14, 2025 05:16 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
