0111 CODE: please HELP!!!
Old Jun 21, 2004 | 02:04 PM
MaxedOutOfCash's Avatar
Pizda Boy
okay, I changed my knock sensor, 02 sensors, & fuel filter....
I get the 0111 code today, I can sense the car running very weird ... What the heck do I do? Where do I start?
Old Jun 21, 2004 | 02:32 PM
Pizda Boy
I think it may be a problem with the fuel filter somewhere...must go and check it now
Old Jun 21, 2004 | 03:01 PM
Pizda Boy
okay, checked the fuel filter...everything OK there...
help, anyone?
Old Jun 21, 2004 | 04:41 PM
DAVE Sz's Avatar
Hooooooonda.....
It's a EVAP code Sam. Check the EVAP thing that's blocking acces to the one spark plug, maybe loose connector. If that's not it, read my PM.
Old Jun 22, 2004 | 05:20 AM
Kevlo911's Avatar
Kevlo for President
0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
Old Jun 22, 2004 | 06:16 AM
Pizda Boy
hey thanks...from your pm i get the feeling that you know something about this... i do have one hose that is ripped right by the strut bar & throttle body . . .i'll send you a pick and maybe you can tell me if that has anything to do with it... but it was ripped for the past 4 months and nothing happened before... i will try to work on it this week.
Old Jun 22, 2004 | 06:17 AM
Pizda Boy
Originally Posted by kevlo911
0111
yeah, i got that far too ....
Old Jun 22, 2004 | 06:46 AM
Pizda Boy
Big D you are the man...
I d/l that neat thing you sent me & the answer was right there.... there is a little hose coming into the EVAP Canister Purge Control Valve, when I put my strut bar on, I ripped it. Funny thing is that it was ok for months & now it went bad... Now I just have to find out what the name of that little hose is...
Thanks Again!
Old Jun 22, 2004 | 08:19 AM
Gen8888's Avatar
Maxedoutofcash can you send me the pm as well. I need to possibly replace my purge control valve since i'm getting the same code as well. Thanks.
Old Jun 22, 2004 | 08:32 AM
hacim105's Avatar
You know I have had this same problem. I fixed my O2 sensors and my Knock Sensor and within 2 weeks I got the 0111 code. I haven't had any idea how to fix it or where it was even located. Big D or someone else could you send me the PM. Thanks alot.
Old Jun 22, 2004 | 08:58 AM
Pizda Boy
guys... all Big D sent me was a diagram of the evap... i will scan it for you since the host is unavailable... but it won't be until tonight.
Old Jun 23, 2004 | 06:15 AM
Gen8888's Avatar
ok thnx....
Old Jun 23, 2004 | 03:18 PM
DAVE Sz's Avatar
Hooooooonda.....
It was much more than the diagram Sam but I guess that's all that is needed for the fix. Am I good or what? Keep in touch man.
sean05
Jan 10, 2007 12:40 PM
CalsonicSE
Jul 26, 2005 05:30 PM
d280c
Sep 13, 2004 04:48 PM
Rogo02SE
Apr 24, 2003 12:07 PM
