New Car, What kind of oil?
Old Jul 28, 2004 | 12:42 PM
Stos95's Avatar
I just bought a 95 Nissan Maxima GLE (Auto). I have 82k miles on it and I want to change the oil asap. The last owner changed the oil every 5k or 6k. What do you recommend I use? A buddy of mine said I should maybe use Blended? Do you think I should use that or what the book recommends?
-Stos
Old Jul 28, 2004 | 02:09 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Mobil One! make sure u use a nissan oil filter also. get nissan parts 25% off at jerryromenissan.com use "maxima" promo code. i bought 10 for dirt cheap
Old Jul 28, 2004 | 02:17 PM
Saddles's Avatar
I second that.
Old Jul 28, 2004 | 03:57 PM
Vaudeville Villain's Avatar
I have 140k on my Max, and I've been using Valvoline MaxLife. It's been working just fine for me. Wonder if it actually works the way it's marketed . . . .
Old Jul 28, 2004 | 06:23 PM
Max Atlanta's Avatar
I used Mobil 1 from day one. I bought my '99 new in December of '98. I recently changed to Red Line oil but IMHO either synthetic would do well. I use a K&N filter or a Mobil 1 filter. I have 142,800 on the clock and she runs like a champ
Old Jul 28, 2004 | 06:42 PM
someone2's Avatar
i have over 160k on my car, and my mechanic recommended adding some engine oil treatment (like STP or any other trusted brand) to my regular oil. i don't use synthetic because it just gets too expensive for an older engine like mine that occasionally slurps up a whole quart of oil for no apparent reason.
the valvoline maxlife and the other high mileage oils are pretty much regular oil with the STP-type additive already mixed in. so do the math yourself and figure out if it's cheaper to buy regular oil + STP or the maxlife oil. just DON'T add the STP additives to the maxlife oil--it will be giving you a double-dose of those additives, which is not necessarily a good thing
also, fram (and possibly other brands) makes a "double guard" filter that has a teflon additive that essentially does the same thing as the STP-stuff. so if you use these filters (i don't--something just seems weird about them) again don't add STP or use the "maxlife" oil because you'd be getting a double-dose of additives which could really gunk up your engine
Old Jul 28, 2004 | 08:25 PM
Originally Posted by someone2
... also, fram (and possibly other brands) makes a "double guard" filter that has a teflon additive that essentially does the same thing as the STP-stuff. so if you use these filters (i don't--something just seems weird about them) again don't add STP or use the "maxlife" oil because you'd be getting a double-dose of additives which could really gunk up your engine
Recently I heard that pretty much everything claiming to have teflon as some magic bulletproof ingredient is bull ... teflon needs to reach a certain heat to "activate" and work wonders, and that heat isn't reached in most applications. An oil filter can get pretty hot, though, so I can't call that one. I heard this after buying a DuPont wheel cleaner with teflon, thinking it would rock, but it's nothing special. I don't know whether the info was correct, but makes at least some sense considering the heat applied to pots and pans and, uh ... woks, and the like.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxgig
Aug 18, 2015 09:17 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
