JWT popcharger + Check Engine
Old Aug 5, 2004 | 08:46 PM
ilyaat's Avatar
Just installed the JWT popcharger on my car.
Did it like this:
Disconnect the air intake cable (i think its called MAF, or the Air Temp cable...there was only one sticking out which you can disconnect and tahts the one I disconnected)
Unscrew all bolts.
Take it out completly.
Put in the JWT popcharger
Put all bolts back on (I tightend them, and can tight them up some more, but don't know how much is enought)
Connect the air intake cable back on
Drive the car ... See engine light ON
Any ideas?
Old Aug 5, 2004 | 09:34 PM
tedo007's Avatar
faster than you think
take it to autozone and if im not mistaking you're not supposed to pull out the MAF...
Old Aug 5, 2004 | 09:49 PM
ilyaat's Avatar
http://www.courtesyparts.com/Merchan...arger_inst.pdf
:shrug:
Old Aug 5, 2004 | 10:07 PM
ilyaat's Avatar
bump, more info posted...plz help out.
If its just the engine light that is on and nothing is wrong, can i just drive around with it and have no problems?
Old Aug 5, 2004 | 11:28 PM
tedo007's Avatar
there is no problem with driving around jus unplug the battery wire and let it sit for like an hour and plug it back in itll clear CEL....
Old Aug 5, 2004 | 11:37 PM
NiNe7-Gxe's Avatar
check the codes and see what it says
Old Aug 6, 2004 | 08:16 AM
ilyaat's Avatar
I would like to hear more opinions on this, so... anyone else?
Old Aug 6, 2004 | 10:11 AM
MAXecutive's Avatar
see if this helps you
http://forums.maxima.org/showthread....7&goto=newpost
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
mikebla
Sep 3, 2015 05:37 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
