HELP, big Bounce problem.. HELP
I have a big problem. First off i have a 97 I30; I bought a complete set of 99 se springs and struts used with 34k miles on them to put on my car since i have 152k and still orginal suspension.
Anyway heres the problem: after putting them on and driving around today for the first time the car is a flying airplane. The rear jumps into the air at any sligtest bump or vibration in the road. I almost crashed into the wall on the highway. I got home and started to push down on the rear and it just jumps back up higher and higher the more you push down on the suspension.
I dont know what could be the problem, i put everything back the right way; i didnt a suspension beofer on my max and never had this problem.
Anyone have any thoughts, I cant drive the car at all .
If everything is installed the right way, then you have defective parts. You should have kept you old springs and just bought struts since srpings rarely go bad. KYB GR-2's would be perfect stock replacements.
a few ?'s
1) Since I have an SE, would the GR-2 be a perfect complement to the stock suspension w/o being harsh or soft? I have no plans on lowering my Max b/c of the roads here in the metro Detroit area
2) I have close to 109K on my '98, should i replace my original shocks/struts at this point or can I wait 'til next spring to do so? My driving style isn't aggressive
Are you guys sure they are blown struts? How can that be with only 34k miles on them. My car had 152k miles and im sure my shox had to be gone and the car never bounced the way this does. when i mean bounce i mean you hit a hole and the car rear jumps to another side...????
Originally Posted by DAVE Sz
Simple, someone sold you blown parts. You should've checked them before the install. GR-2 are pretty much stock replacement struts.
Thnx
maximus_pr: you're talking about agx, right? I think only agx are problematic. The GR-2's I've owned seem good. And I don't hear very many complaints of the GR-2 for stock springs. I think they're aggressively tuned, yet not harsh.
Usually, a new strut will be difficult to compress, and expand quickly to full length (pull on strut to be sure)
A worn strut will compress easily, and expand slowly. Sometimes if it's really dead, it won't expand at all. Or if it's leaked, it won't expand to full length.
But if the suspension is still on the car, it's up to the driver to figure it out. Sorry!
Jae
Jae
Jae
Jae
Jae
Jae
New struts should not expand quickly. They should be hard to push down, but not rebound fast. They not only control the compression of the spring but also the rebound of the spring. In slow and out slow. A blown strut just won't rebound at all.
It really does not sound like blown struts to me. The ones you took off were surely blown anyhow with 150k miles. I have ridden on blown struts and the car does not jump around like that. Sure it bouncy and all, but the car won't react to the way your describing.
The struts you put on couldn't have been any worse than the ones you took off. I would just check over the install to make sure everything is there that should be.
