Can't get fuel filter off
Old Sep 2, 2004 | 06:21 AM
mikez's Avatar
Removed the fuse, loosened the hose clamps, but I couldn't get the hose to pull off. So I turned the motor over again (to try to remove fuel pressure), but still can't get the hoses to budge.
Anyone else have this problem? I'm afraid I'll break something if I keep pulling on it.
Old Sep 2, 2004 | 06:40 AM
MrEous's Avatar
^ Jeff™
Try opening your gas cap...this helps to depressurize.
Are you using some sort of pliers to help get the hoses off? Try using a twisting/pulling motion when using pliers, this has helped me.
Old Sep 2, 2004 | 06:49 AM
Daily Interlude's Avatar
Right, always try to twist the hose around the connector to break it free first. Then try to pull (while twisting a bit).
NmexMAX's Avatar
dot dot dot ...
Use pliers to crimp crush the barbed ends of each side of the filter to make them small enough to slip the hose off, besides you're not planning on keeping that old filter in mint condition are you?
Old Sep 2, 2004 | 06:50 AM
sagamax's Avatar
Give me a Bud Light Holmes
twist and pull....just pulling wont always do it. try opening your gas tank just to let some more pressure out.
Old Sep 2, 2004 | 08:04 AM
Tyrexx's Avatar
you need to twist the sht out of the hoses, keep twisting back and forth, it will start to loosen.
Old Sep 2, 2004 | 08:07 AM
NmexMAX's Avatar
dot dot dot ...
Crush the ends guys use common sense. . .then the end will be smaller hence will come off easier.
Old Sep 2, 2004 | 08:13 AM
mikez's Avatar
Thanks...I've give all your suggestions a shot.
Should I be worried about broken pieces if I use a pliers to squish the old barbs smaller.
Old Sep 2, 2004 | 08:17 AM
kenju4u's Avatar
This was a pain for me too...one thing that really helps to get your hands really in there is to remove the intake manafold just like when you clean the trottle intake. After you remove it you will have a lot more space to work with...you gotta crush the filter ends inside the hose or just twist with your hands it comes off eventually. Just dont damage the hose.
GLuck!
Old Sep 2, 2004 | 08:37 AM
nismology's Avatar
That's good advice only if the hoses are in good condition. If they aren't, you'll crack the hoses which isn't such a good idea, at least not for me.
Old Sep 2, 2004 | 08:41 AM
Sprint's Avatar
You should buy some replacement hoses just to be on the safe side.. but usually i just keep turning the fuel filter until it comes loose.
I am hoping you took the AIR box off so you can get better leverage
Old Sep 2, 2004 | 10:16 AM
dmBK's Avatar
How 'bout them cliffs?
i did it last saturday. loosened the clamps, so they slide freely, then sprayed with the stuff that makes the bolts loosen-up easier (forgot what its called!). then used a flat-head screwdriver, and stuck it between the filter body and the hose, and pulled. came out relatively easy. twisting a dry rubber hose off the filter is a pain.and gotta be careful with that "tree" of metal piping under the intake, cause if you break them off, apparently it will cost a pretty penny to fix.
hope this helps.
Old Sep 2, 2004 | 11:35 AM
Jepht20's Avatar
Custom User Title...
i had trouble the first time i tried and couldn't get it. the next time i tried, i used a flat head screw driver like dmBK said, and just pryed the hose off. worked great! goodluck
Old Sep 2, 2004 | 01:19 PM
bearded's Avatar
Me and my buddy tried to pull the hoses off for like ten min before they came off. Just be patient and pull hard as a motherf.....
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
