engine tunning
Old Apr 9, 2001 | 05:43 PM
ybelm620
i have a 97 se 5spd and i wanted to do some engine work. i was thinking of replacing my stock cams and pistons and try to install the 1996 300zx twin turbo cams and pistons. i also wanted to port and polish the heads. will this work or is it impossible, and how much horses will i gain if i was to do this.
Old Apr 9, 2001 | 05:58 PM
teejnut's Avatar
talk to "don in texas" he would know... he's currently "building" a VQ engine rite now
Old Apr 10, 2001 | 08:10 AM
Daniel B. Martin's Avatar
Save your money
300ZX parts swap... The two engines are different and there is essentially zero parts interchangeability. For example, the 300ZX bore is 3.43 inches and the Maxima bore is 3.66 inches.
Port & polish... this is a waste of time and energy unless you are an out-and-out racer. To get any real benefit you also have to rework the intake and exhaust manifold.
Old Apr 7, 2007 | 01:33 PM
98SEHBRN's Avatar
Originally Posted by 98SEHBRN
If you install the cams and pistons of the 300zx turbo engine....you will lose power.
Those components are designed to work with the 300zx turbo engine ONLY.
You will not see any gains unless you install the whole setup.
Mother of God and sweet Jesus.. This thread is older than some members on here
Old Apr 7, 2007 | 01:41 PM
2da mizzax's Avatar
Ok. enough is enough. He should be banned just for being an idiot.
matty's Avatar
A little tribute to Daniel B. Martin. That man knew his stuff
Old Apr 7, 2007 | 01:43 PM
NmexMAX's Avatar
dot dot dot ...
he rocked
Old Apr 9, 2007 | 06:37 AM
phenryiv1's Avatar
Mod her. Ate her.
unbereivarbre.
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
