I figured it out!!
Old Apr 10, 2001 | 01:18 PM
toubis's Avatar
After going crazy trying to locate the leak in my trunk, I finally found it!!
I had my rear window replaced about two years ago at the dealer because my rear defrost didn’t work, now I need to know do I have to send it in to change the window or can I seal it my self?? Also, water is accumulating in my spare wheel well, any suggestions how to rust proof it?? I see a little rust; I don’t want it to spread.
Old Apr 10, 2001 | 02:15 PM
Daniel B. Martin's Avatar
If you can identify the exact location of the leak, you can probably "goop it up" with a sealant. The best repair requires removal of the window, application of a bead of sealant, and reinstallation of the window. This is a job best done by a professional, as there is some risk of glass breakage.
Please contact the dealer which installed this window two years ago. They might do this repair at no charge, or at a discounted rate. It doesn't hurt to ask.
Old Apr 10, 2001 | 06:03 PM
Vitaly O.'s Avatar
I had the same problem
last summer i notice that I had this funny smell in my car and what do you know i had water in my trunk where the spare tire is so this is what i did
I took out the spare tire drained all the water lett it dry with an open trunk then if you look at the bottom of your trun you can see that there is two black circles that are rubber plugs I do not know why they are there but I took them out put a selent on them and pluged them back in and then put selent on them again around them and no problems ever since
Old Apr 12, 2001 | 08:34 AM
toubis's Avatar
Any idea on how to prevent the rust from spreading?
Old Apr 12, 2001 | 08:47 AM
dwapenyi's Avatar
Re: I had the same problem
Uh, those rubber plugs you describe are for letting the water out.
DOH!
DW
Old Apr 12, 2001 | 05:55 PM
Vitaly O.'s Avatar
then how did the water get in there
DDDUUUUUUhhhhhhhh
And never did it again
Old Apr 12, 2001 | 08:55 PM
BIGMAX's Avatar
This doesn't really rlate to the topic but I thought it was funny.
I backed my 92 camry out of the driveway one day and saw a huge stain running down the driveway. I was puzzled.
Next day I open the trunk to see that I had forgotten to dispose of the old battery I put in there.
The battery had tipped over and leaked acid. It ate right through the trunk.
Oh yeah, the car reaked of battery acid for the next two months!
Did i fix it? Nope
Did it rust? Don't know never looked
Old Apr 12, 2001 | 09:56 PM
Ravq's Avatar
You can spray it with some Rustoleum. It turns the rust into primer. That should prevent it from spreading. They also make another chemical that does it but I can't seem to remember what it is called. You can get it at hardware stores.
Old Apr 13, 2001 | 03:50 AM
Ramius83
As Ravq said, spray some rustoleum on it and let it dry. Maybe put about 2-3 coats on it to really prevent the rust from spreading. Also, go underneath the car and spray some there as well. When it dries, get some paint that matches your car, white in my case, and spray that over the rustoleum. That will jsut "seal" up the car much better. Hope this helps.
TallTom
57
Oct 14, 2025 05:16 PM
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Mar 29, 2016 11:08 AM
fx4five
Oct 18, 2015 06:57 PM
09maxshawn11
Sep 30, 2015 10:28 AM
