I suggest anyone to clean there throttle body!
Old Oct 14, 2004 | 08:58 PM
  #81
goodhead's Avatar
get seafoam deep creep it worked very well for me
Old Oct 15, 2004 | 05:30 PM
  #82
tpduke112's Avatar
Ok, just finished cleaning my throttle body and my first impression was great. Smoother idle, and it seemed to shift much more smoothly and less jumpy (not sure if this had to do with the throttle body cleaning). Acceleration was definitely smoother. It was actually very easy to clean also. I used Carb, Choke, and Throttle Body Cleaner which only cost me 2.50 at Advance.
Old Oct 15, 2004 | 06:08 PM
  #83
vipervadim's Avatar
I like Maximas
If you really want to clean the whole intake manifold, throttle body, and fuel lines and injectors look into sea-foam.
midway auto supply sells the motor treatment and the deep creep relatively cheap. you can pour 1/2 of sea-foam motor treatment into oil 1/2 into the intake manifold through the brake booster cable and a full can into the gas tank for cleaning and preventing deposit buildup in fuel lines and injectors. for the throttle body they reccomend spraying a can of sea-foam deep creep. I performed the cleaning on my engine, (2 cans of motor treatment and 1 can of deep creep) turned it on, and it smoked a lot for 15 minutes (the whole block was covered in white smoke from the exhaust) and i went for a nice drive revving low and high. afterwards it was like driving a brand new car. the revs are smooth and fast and the idle is planted at 675rpm. I changed the oil after 1 month (roughly700 miles) the oil was very dirty and had little bubbles when draining after the new oil the car pulled even better. I will continue to use sea-foam on my engine every other oil change (8K miles -- i only use AMSOIL)
http://www.midwayautosupply.com/deta...ption.asp?4456
try it and you will not be disappointed, they also make automatic trans-tune to clean all the deposits in the transmission (add a can to your ATF, also works well)
http://www.seafoamsales.com/motorTuneUpConsumer.htm (sea-foam Website)
if you don't believe me ask other members of the org who use it.
Old Oct 15, 2004 | 08:33 PM
  #84
kcryan's Avatar
alright im confused about sea foam what does it do and where do i put it?
thanks
KC Ryan
Old Oct 16, 2004 | 12:55 AM
  #85
amulla01's Avatar
where can i buy these products of seafoam? they available in auto stores? might use it for my auto tranny hmmm
Old Oct 16, 2004 | 12:57 AM
  #86
amulla01's Avatar
oh and how much is it per can?
Old Oct 16, 2004 | 01:03 AM
  #87
maxima_kid's Avatar
Originally Posted by 99 SE-L
first of u need to unscrew the clamp on the intake manifold its aflat head u take off the whole intake does not matter stock or after makret once u take it off u will see inside the throttle body a little flap u flap it up make sure your car is on and while u are doing it either have someoen hit the gas pretty hard or do it by ahnd wiht the cable and spray in there nto too much but a good amount the car will idle hard at first then it will be good the car might stall from the lack of air but turn it back on and hit the gas a little then s put the intake back on screw the clamp on and test drive ENJOY
I dont get it. Its like your stuttering and your instruction is one long sentence. Actually, I take that back. There's no period.
Old Oct 16, 2004 | 08:17 AM
  #88
kcryan's Avatar
just made a visit to autozone for some brake fluid for the allante and some atf fluid so i can freshien my i30s power steering fluid. they had sea foam and i got a bottle of the deep creep. it was 5.49 but i think they other types of seafoam were a little cheaper.
now do i just start spraying into the intake or do i open it up to get to my throttle?
also what other uses does this stuff have? im bored and will try just about anyting interesting right now.......
Old Oct 16, 2004 | 02:52 PM
  #89
southeast_first's Avatar
i just did this, and replaced my air filter too (the old one was gross as hell). my car def. feels a lot better, pulls a little harder, takes off a little smotther, all that. expect a hard start right when you reconnect everything, guys.
Old Oct 16, 2004 | 05:43 PM
  #90
tpduke112's Avatar
Really? Mine started pretty smoothly right when I reconnected everything.
Smackasmith
Feb 1, 2016 12:40 AM
Maxie40
Sep 14, 2015 11:28 AM
pjgreek
Sep 9, 2015 09:30 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
