Whats wrong with my hazard lights????
My hazard lights do not work at all but my turn signals do. ??? WTF is goin on i dont understand it i looked for the fuse and theres nuttin wrong... has someone ever had this problem???
do you have the factory alarm - and if yes, do the blinkers blink (together) when you lock the doors/arm the alarm... if yes, I think nismos14 had the same problem - see if he found a fix... I don't know what the problem is, but I call tell you its not the flasher relay (since replacing that didn't fix it for the other org member)... it might be a bad hazard light switch.
There are two separate flashers... there is one flasher for the turn signals and one flasher for the hazards. They are identical flashers (interchangeable) but nonetheless, they are two separate flashers. I suspect one died while the other is OK. Simply replace the flasher and that should do it.
To the OP:
The FSM lists the following possible causes for your symptoms:
1. Blown 10A fuse in fuse block (Fuse #11)
2. Hazard switch faulty
3. Open in hazard switch circuit
You weren't fidding behind the center console before this happened were you?
Originally Posted by njmodi
I don't think this is true - i.e. there is only one flasher relay. If you really do think there are two relays - where is the 2nd one located? Neither the FSM or the Haynes manual mention a 2nd relay.
His problem is a fuse. I had the same thing happen. I replaced one fuse and the hazards worked but when trying to make a turn the blinkers didn't. Check the tail lamp fuse, check all of them.
Maxima30
Sep 7, 2015 06:13 PM
