Stereo Problem
Old Nov 10, 2004 | 02:19 PM
Umass021's Avatar
Stereo Problem
I recently put a stereo in my 95 maxima. When I turn on the subs my radio sounds bad unless I use a cd then it sounds fine. It sounds all distorted until I shut off the subs then it sounds fine or use a cd. What do you think it is?
Old Nov 10, 2004 | 02:21 PM
chenzarino's Avatar
Radio always sounds crappy, listen to CDs.
Old Nov 10, 2004 | 02:22 PM
Umass021's Avatar
Yeah but it is bad it sounds good with the subs off.
Old Nov 10, 2004 | 02:33 PM
njmodi's Avatar
Do I get a tax break?
Some grounding issue from the subs... causing interference with the antenna.
Old Nov 10, 2004 | 02:59 PM
Batxel's Avatar
blah
Make sure your hu and amps have good grounds. Make sure they're connected to the chassis, use sandpaper to clean the surface.
Old Nov 10, 2004 | 09:03 PM
erty67's Avatar
Decal Specialist
is the amp for the subs hooked into the RCAs on the radio? ...or line level off of the rear speakers? Sounds kind of strange that it's only the radio and not the CD. Do your audio settings change when you change from radio to CD? some radios have separate audio controls for radio and CD. I don't know how far from RI you are, but I'd be willing to meet up w/ you, worst case.
Old Nov 10, 2004 | 09:15 PM
Umass021's Avatar
I am not far from there. The radio setting are the same as cd. I think it has something to do with the antenna but I am not sure.
Old Nov 10, 2004 | 09:29 PM
erty67's Avatar
Decal Specialist
hmm...maybe. well, like I said, your welcome to come down. I'm no pro, but I'm pretty good with car audio.
ivorton23
Sep 28, 2015 09:08 PM
homewrecker
Sep 24, 2015 07:01 PM
ajahearn
Sep 19, 2015 03:03 PM
EdRomo86
Sep 12, 2015 07:49 PM
Violator
Sep 9, 2015 10:14 AM
