Problem Reading Oil Dipstick...
Old Nov 10, 2004 | 06:49 PM
HarrisH's Avatar
I checked the oil level last night after the car had been sitting for 6-7 hours maybe a little less the oil read 2 millimeters BELOW the H mark, I was like ok it's fine. Check it again in the morning same deal. Drive for 2 miles total 20-30 minutes tops come home park my car. Head off to class check the dipstick again this time after the car had been sitting for 3 hours the level read 5-6 MM below the H mark I was like WTF??? Seemed like it lost .25-.35 quarts. Now I assure you all that I am not leaking oil anywhere I park in a garage no leaks what so ever. I am not burning oil at all no smells or smoke, and my compression is good. Now a friend of mine told me it's probably the dipstick so I would appreciate it if someone can give me information on how to read the dipstick and or why the readings are like that. Thanks!
Old Nov 10, 2004 | 06:51 PM
f550maranello2's Avatar
thats cuz u arent checking it correctly. ur not posed to check it after 7 hours cuz all the oil settles to the bottom. u want to check it 10 minutes after u turn off the car. good luck
Old Nov 10, 2004 | 06:54 PM
PLUMMAXSE's Avatar
Just keep checking the car after it's been sitting for 6-7 hours and go with that dipstick reading. Even though you let the car sit for 2 hrs, thats not long enough to get a good reading after driving for short trips. 1/4 quart of oil is still stuck up in the engine and hasn't made it down to the oilpan. My feeling is your car is just fine!!
Old Nov 10, 2004 | 06:58 PM
PLUMMAXSE's Avatar
It depends what type of oil he's using. If conventional and the car has been totally warmed up, 30 min driving in cold weather, that will work. But with synthetic oil, it takes much longer for the oil to filter back to the oilpan. I just check mine(synthetic) in the morning after it sits all night.
Old Nov 10, 2004 | 07:00 PM
HarrisH's Avatar
You are supposed to check it when cold. Reputable mechanics and people here will till you to check it in mornings or what not. The oil doesn't settle in 10 minutes or so I think correct me if I'm wrong.
Old Nov 10, 2004 | 07:07 PM
Yea man thats execally my point... if u check it after 10 minutes enough oil should go to the pan to have a good reading. its kinda hard to explain. its like this... u want to measure the oil that is activly circulating, u dont really want to measure the oil when every last drop from all over the engine has settled int he pan. sorry for the weird explination.
MAXSE5SPD
Sep 17, 2022 04:00 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
intimidator
Sep 5, 2015 07:23 PM
A32goldylocks
Sep 2, 2015 06:39 AM
tnewbs
Aug 28, 2015 10:15 AM
