how do you take out fog lights
Old Nov 16, 2004 | 11:27 AM
wickedmax's Avatar
how do you take out fog lights in a 4th gen?
do you just use a flat head and pop them out and disconnect the wire? or are there screws somewhere i need to unscrew?
Old Nov 16, 2004 | 11:30 AM
chenzarino's Avatar
Take em out and mail them to me
Old Nov 16, 2004 | 11:34 AM
mzmtg's Avatar
Minister of Silly Walks
With a hammer.
Old Nov 16, 2004 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
Should be in your owners manual. I have a 95, so my method won't work, maybe it's the same concept, but I don't know.
Pop off piece of plastic, loosen bolt, and from there on, it's up to you.
Old Nov 16, 2004 | 11:39 AM
drunkenmunky23's Avatar
there should be a screw or 2 on teh inner side and then on the outterside there a pop thingy that you need a screwdriver for...and the then all you gotta do is take off the harness, its easy but that pop-out **** mite me a lil tough...
Old Nov 16, 2004 | 02:09 PM
A32Matt's Avatar
on the front of the fogs there is a rectangle piece taht you pry upwards on and it will come out. then there is a 10mm bolt that you take out and the fogs come right out.
Old Nov 16, 2004 | 02:12 PM
Nick7455's Avatar
ok its a 97.....use a phillips head and loosen the 3 screws....then pull out and proceed to do w/e u needa do.
Old Nov 16, 2004 | 02:14 PM
A32Matt's Avatar
the fogs are mounted differently on a 97 compared to a 95?
NmexMAX's Avatar
dot dot dot ...
That's for a 1995, he has a 97+
Old Nov 16, 2004 | 06:18 PM
ManualMaxima's Avatar
5th Gen till she dies!
if you just look at it and try at you will get it and you will learn more than you d by someone just telling you. Just go out and do it...i bet you have not even looked at it yet cause if you did ti wouuld be a simple task....
take some time and go find out.
Old Nov 16, 2004 | 10:34 PM
monty95's Avatar
yeah, i tried takin my 95 ones out with a philips, i stripped the screw, then i thought about drilling it out....right when i was about to do it, i had second thoughts, then i went out and bought a socket extension, and used a 11mm....(i may have used the wrong one, A32Matt said its a 10mm) but anyway...i got it out, but...this doesnt apply to a 97 and i duno why i posted this......
Old Nov 17, 2004 | 06:10 AM
NmexMAX's Avatar
dot dot dot ...
This is how a lot of us learned, takes less time and is less confusing.
Old Nov 17, 2004 | 06:12 AM
lilaclucymaxima's Avatar
Team Ramrod
look at it and figure it out, if u cant do that then look at your owners manual
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
