Pulsating Acceleration-bouncing RPM.. what can this be?
Old Nov 19, 2004 | 09:41 AM
viktornguyen's Avatar
This mornin while drivin in the city, i stopped at a red light. When it turned green, i lightly pressed my gas pedal to start moving...
All of a sudden, the RPM needle was bouncing up and down like it's struggling to get gas, burn gas, or clogged pipes or something. RPM would bounce between .5-2000 RPM or so... iono, u guys tell me. Went a few more lights, and the same thing happened.
But in addition to this, i think whatever is causing this, is probably causing my difficulty starting as well. In cold weather, the only way my car would stay started is if i press on the gas. Or else it would just die.
Other facts: changed to +4 Bosch spark plugs few months ago (i know this aint good, but they are brand new and shouldn't be causing this much of a problem this early), almost time to change my oil (3000+ already since last change), and my fuel filter needs to be changed which i will be doing.
What i think it is:
possible clogged injectors?
very slim chance of wrong spark plug type?
very dirty fuel filter?
Old Nov 19, 2004 | 09:47 AM
PTownMax's Avatar
I still miss the max
ECTS- Engine Coolant Temp Sensor
probably gone bad, i had the same problem about a month back
Old Nov 19, 2004 | 09:49 AM
njmodi's Avatar
Do I get a tax break?
Bosch ? Put in NGKs and then get back to us.
njmaxseltd's Avatar
Was the engine RPM's actually jumping around or was it only the tach that was really jumping. If it was just the tach, then I'd say you have a grounding issue.
Old Nov 19, 2004 | 10:09 AM
It was the actual engine, not just the meter, i could feel the car jerking sorta...
ECTS- Engine Coolant Temp Sensor - what does this have to do with rough acceleration etc. ? just curious.
Old Nov 19, 2004 | 10:14 AM
PTownMax's Avatar
same question i had asked, the rpms are trying to drop while your gettingon the gas, sounds like exactly what i went thorugh and thats was how i solved the problem...
Old Nov 19, 2004 | 10:15 AM
NM here's what i found:
ECTS- Engine Coolant Temp Sensor is:
-a temperature switch (~100 F) which goes to the idle control module
-the thermo-time switch which activates the cold start injector
-the temperature sender for the gauge
-a temperature sensor for the fuel injection
-another temperature switch (176 F) wired in parallel with the previously mentioned sensor
depending on which one of them fails...
-idle speed could be out of whack
-it will be hard to start when cold
-non-working temp gauge
-incorrect fuel mixture while the engine is warming up
-warm running might be less than optimal as the motronic box might not know to switch to closed-loop mode
Is it hard to change this? and how much is it?
Old Nov 19, 2004 | 10:17 AM
njmodi's Avatar
25 bucks, 10 mins, in the upper radiator hose near the valve cover.... if you have a Haynes - its shown in there... if you don't have a Haynes, nows a good time to get one.
Old Nov 19, 2004 | 11:49 AM
A32Matt's Avatar
i'm having a similar problem, around 40 mph if i am on a slight downhill grade and not giving it any gas, my rpms bounce up and down until i give it some gas. really annoying. can't figure out what it is though.
Old Nov 19, 2004 | 05:59 PM
Cujogood's Avatar
I have the same problem. I was told it was a vacuum leak.
Old Nov 19, 2004 | 06:28 PM
A32Matt's Avatar
hmm...as far as i know all my vacuum sources are fine, no leaks. it frustrates me not knowing if more problems are going to arise from this.
MaximaDrvr
Aug 19, 2015 08:20 PM
HIDManic
Mar 3, 2004 07:25 PM
Cumalot
Mar 13, 2003 05:36 PM
dnoah333
Jan 22, 2002 08:24 PM
