Well, my engine is falling out...
Old Jun 2, 2006 | 01:08 PM
  #41
69CHARGER_RT's Avatar
Is the replacement part bolted in or do you have to cut the old section out & weld in the new one?
Old Jun 2, 2006 | 01:31 PM
  #42
tavarish's Avatar
fwd gone rwd cr00
the factory one is bolted in AND welded, so I have to cut out the part, and bolt it on. I'm gonna just bolt it on long enough for a shop to come and weld it for me.
Old Jun 4, 2006 | 04:48 PM
  #43
Broaner's Avatar
2060lbs and falling...
This thread just will not die. Its good to give people ideas on the cheap though.
Old Jun 11, 2006 | 06:10 PM
  #44
aznsap's Avatar
Originally Posted by DDELINQUENTONE
i had my lower rad support changed twice
the first time the body shop used a cheap aftermarket replacement wich fell
apart within six months i made them replace it using a oem lower rad supports
its been about 2.5 yrs since an still good as new i also had then spray undercoating to prevent anymore rust i paid $450.00
you guys have the part# for the OEM lower rad support?
i guess the undercoating spray may be a good investment to prevent rust a little longer.
Old Jun 11, 2006 | 06:13 PM
  #45
aznsap's Avatar
nevermind i found the part#: 62500-40U00
it retails for $334, so you can probably find it cheaper somewhere else.
Old Jun 11, 2006 | 10:16 PM
  #46
gx2nds4's Avatar
what brand of anti-rust spray would you guys recommend? or an example of a good one. I'd have to go check my car and hopefully it won't be too late.
shilov
Feb 19, 2024 09:40 PM
bbsitum
Sep 6, 2019 07:31 PM
Stagnet04
Sep 14, 2015 11:28 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
