What is this in the engine bay? (Pic inside)
Old Dec 14, 2004 | 08:43 AM
Powerman5115's Avatar
The silver thing in the middle with 2 hoses and one electrical connector.
It has a hose connect to what I believe the the PCV (The black round thing right inder the FSTB to the right of the throttle cables),and a hose connected to the IM right after the TB and right before the IAC. It is not bolted down, it just sits there. The hose going to the IM was spliced for the vacuum for my MEVI. That's the best description I can give, please help me out.
Mooney
Old Dec 14, 2004 | 09:32 AM
I30tMikeD's Avatar
Mooney
That is the EVAP solenoid. What your calling the PCV valve is the evap part of the evap system as well. The reason that it is not bolted down is because the evap system for the maxima in other markets is either else where or non-existant. For example, the I30 evap system is not on top of the manifold like the maxima's is. So an I30 manifiold or an MEVI will not have a place to bolt it to so it just has to lay there.
Old Dec 14, 2004 | 10:22 AM
matty's Avatar
Or make a nice braket like I did and Use one of the other holes in the manifold, bring the braket accross and bolt the EVAP selenoid to the braket
First I used large tydowns but that didnt work and then I tried Wire....the braket is a good idea
-matt
Old Dec 14, 2004 | 10:36 AM
meccanoble's Avatar
Sports Button FTW
i looked under my hood and saw mine is bolted down too. Seems to be in the way if you plan to change spark plugs....
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
maximusrising
Sep 4, 2015 06:31 PM
dcardello
Sep 3, 2015 11:44 PM
Hailstatejig
Sep 2, 2015 06:52 AM
