Strange noise from engine bay
Old Dec 18, 2004 | 11:36 PM
ebunoye's Avatar
whenever cold starting my Max. I hear a rattling noise from the passenger side of engine compartment. when engine is hot the sound goes away. I spoke to a friend who thinks its something with my timing chain.
Anyone experience similar issue or could shed some light? Any and all suggestions will be highly appreciated.
Ebun
Old Dec 19, 2004 | 04:55 AM
MilesA's Avatar
Most likely this is your timing chain tensioner. If the noise goes away after the engine warms up, most likely it is harmless, but annoying all the same.
Technical Service Bulletin:
http://www.jatan.net/tsbs/047941.pdf
How to fix:
http://forums.maxima.org/showthread....t=timing+chain
Please be sure to read all the FAQs and How-tos for the 4th generation. This is a very common problem.
Old Dec 19, 2004 | 07:04 PM
Kinger402's Avatar
A quick question. I have this problem. If it is a Technical Service Bulletin, Does the dealer repair this for free? or is that just in recalls. Also is it really harmless or should i get it fixed?
Old Dec 19, 2004 | 07:08 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
TSB just aids in the service of the problem. only recalls are free. if you bring in the TSB, the'll do it, and still charge you. your only helping the technition.
Old Dec 19, 2004 | 11:04 PM
BangNgears's Avatar
i never really heard or saw any1 blow a timing chain on a max, but if its making noise now i would spend the time in the garage and the pennies on the part an fix it.
seesole
Sep 14, 2015 12:38 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
