HID/Alarm potential problem.
Old Jan 4, 2005 | 12:52 PM
queenambeach's Avatar
Yo I got a 98 I30 and I installed a HID kit some time ago. I know I should post this in the I30/I35 forum but this can apply to Maxima also. It wasn't till the other day that the thought hit me that if my alarm goes off, then my headlights would start flashing constantly until my alarm goes off. That is really not good for my bulb nor ballast. Has anyone had this problem? Does anyone have a solution?
Old Jan 4, 2005 | 01:29 PM
Chunger's Avatar
My other car is a Hybrid
Yes that is a problem but it would only occur with the factory alarm when someone actually opens the car door unless you have your aftermarket alarm hooked up to the headlights too.
Old Jan 4, 2005 | 03:03 PM
HomerMAC's Avatar
Donating i30 Owner
as explained above.. a respectable electrician will be able to rewire the system so ur blinkers flash.. or parklights.. not the head.. or hell wire u p the fog to flash.. heh.. just a thought..
Old Jan 4, 2005 | 03:06 PM
Maxima lover
That is how my dads 2002 is. It also goes off when you hit the panic button. When the thief hears the alarm, he definitely won't stop once he sees he's going to get HID's too. It’s probably some find of relay. I think there’s a couple of relays for the alarm. I would take 1 out at a time and then try it to see if your headlights still flash.
Old Jan 4, 2005 | 08:00 PM
ManualMaxima's Avatar
5th Gen till she dies!
i bet you have a mccuallah kit or however you spell it. The problem is that your hid kit is hooked up t your high beams. When our cars alarm goes off it flashs the high beams, so swicth the wire between your high beems and your lo-beams and your problem should be fixed.
BTW i do not think it is to good for the bulb and ballast either...
Old Jan 5, 2005 | 05:40 AM
Nah I didn't put the mccullah kit in. I hear that they are crap! But thanks for the advice. Hey where can I get a in dash monitor like the one in your sig? I've been looking for one for a while.
Old Jan 5, 2005 | 06:40 AM
C MAX's Avatar
like he said the output for our alarms only goes to the high beam light. so if you hook it up to the low beam you wont have any problems. i had hid for over 3 yrs no alarm issues.
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
