kyb agx level
Old Jan 6, 2005 | 09:37 PM
206maxima's Avatar
kyb agx level
i got new shocks; what level is the best for the road? meaning comfort+excellent handling.
Old Jan 7, 2005 | 12:24 AM
Oblongshapes's Avatar
im rocking 4 in the front and 4 in the back.... but thats a little stiff, but i love taking the turns..... Go 3 in front and 4 or so in the back, just mess around with it... its to your preference
Old Jan 7, 2005 | 04:37 AM
deezo's Avatar
Those things are so stiff, it's hard to tell the difference when you adjust them. I use 1 in the front and 4 in the rears (when I had the rears in).
Old Jan 7, 2005 | 04:46 AM
amb4081's Avatar
2 in front 4 in back (H&R springs). I remember driving home on a bumpy city road after autocrossing. I had left it on the hardest setting front and rear...Boy did it jar the car until I pulled over to change the settings!
Old Jan 7, 2005 | 05:08 AM
mzmtg's Avatar
Minister of Silly Walks
I'm trying to decide between 3/6 and 2/6.
But I wont settle on anything until I get new tires next week.
Old Jan 7, 2005 | 05:48 AM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Not everyone will run the exact springs, tires, bushings etc. There are differences in the factory rear suspension between model trims you're probably not aware of. Also weather will change the viscosity in the dampers fluid so what may be feel good in LA will ride like **** in the northeast. You have to play with those settings and drive around until you determine whats the best compromise of ride and handling for yourself.
I have KYB AGX + Progress springs and Motivational rear shock mounts (like what mzmtg is selling). Stock Hondas generally have smooth rides and good handling and usually rely on relatively soft springs coupled with firm dampening for their suspension setup and I tried to mimick that by keeping my AGX settings stiff since aftermarket lowering springs are much stiffer than stock springs. I started with 3F/6R, 4F/8R, went back to 2F/4R etc etc etc and found that 3F/6R was the best compromise for me.
Old Jan 7, 2005 | 11:01 AM
206maxima's Avatar
i see. i'll try those setting too VEE. thanks!
Old Jan 7, 2005 | 11:25 AM
NyCzBuBBa's Avatar
TOO STIFF FOR ME!!!!!!!!! I'm on 1 and 1 and it's freaking stiff I need new springs. Maybe get some coil overs
Old Jan 7, 2005 | 11:27 AM
apbrian112's Avatar
that's what i've been deciding on. when i first got my agx's i set them at 3/6. after a couple of months i switched them to 4/8 (canyon run with socal guys) but when i went to change them back, i set them at 2/6 and the ride is definately more forgiving when i go over bumps... my dilemma is that sometimes it's a little too forgiving and i bounce. ah well, i'll experiment some more this weekend.
Old Jan 7, 2005 | 12:05 PM
Broaner's Avatar
2060lbs and falling...
4 on the front is way to stiff for pure performance. It gets bouncy. Kinda like wheelhop except while turning hard. The suspension binds up on slight road imperfections and pushes the car up caust loss of nearly all traction for a moment but then it comes back down and you are left gripping the wheel. I run 3/7 at all times.
mclasser
22
Nov 12, 2020 01:58 PM
maxima-junky
Oct 7, 2015 06:13 PM
sliptap
Sep 30, 2015 05:57 AM
