help replacing caliper
Old Jan 11, 2005 | 12:10 PM
zx2max's Avatar
can someone give me quick overview on how to replace by rear caliper. i have never done it so i dont want to mess up my e-brake or anything. i ordered the factory service manual the other day but havent received it yet.
Old Jan 11, 2005 | 01:03 PM
C MAX's Avatar
remove the two caliper nuts, then remove the cable for the E brake. its as simple as that.
Old Jan 11, 2005 | 01:09 PM
zx2max's Avatar
what about the brake line. i amhaving a hard time getting that damn bolt loose
Old Jan 11, 2005 | 01:19 PM
C MAX's Avatar
spray some wd-40 on it its probably rusted. you have to remove the caliper from the rotor so you can have somoe room to manuever the cable. you have to release the lock nut to loosen the cable so you can slip it out.
Old Jan 11, 2005 | 01:44 PM
deezo's Avatar
.................and buy a Haynes manual or download an FSM.
Old Jan 11, 2005 | 04:25 PM
sryth's Avatar
Remove the ebrake cable end with a pair of pliers while turning the lever w/a socket wrench.
Remove the banjo bolt and remove the brake line and simply disconnect the caliper mounting bracket (torque member) by removing the two (19mm heads?) bolts.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
