Rear axle seal leak question...how much $$?
Old Jan 14, 2005 | 12:13 PM
tallica62's Avatar
My mechanic just told me that I have a rear axle seal leak. I guess my tran. fluid. He said it would prob. run between $150-200. Is that a good price? Is this something that I could fix my self (im a newbie when it comes to cars, but willing to learn). HAs anyone else had this problem and what can it lead to?
any other info about this problem would help too...thx
Old Jan 14, 2005 | 12:31 PM
tallica62's Avatar
is this known to be a common max. problem?
Old Jan 14, 2005 | 01:18 PM
MDeezy's Avatar
I've never heard of the rear axle seal leaking, not to say it cant happen but I've never heard nor read a thread about it.
got me
Old Jan 14, 2005 | 01:21 PM
mzmtg's Avatar
Minister of Silly Walks
Does he mean the axle seals, or the REAR main seal?
These are two totally different animals.
Old Jan 14, 2005 | 01:55 PM
tallica62's Avatar
im almost positive its the axle seal
Old Jan 14, 2005 | 02:08 PM
Jeff92se's Avatar
I'm needing a caw
rear axle seal is a combo contradiction of terms.
1) maxima doesn't have a rear axle perse. aka no rear driveline
2) There are seals back there but on each wheel. Not on the non existent axles
3) There are two axles but they are on the front of the car. Not the rear. But they do have seals and they can leak.
4) There is also a rear main seal. But it's not in the rear of the car, nor is it on any axles.
so I'm
Old Jan 14, 2005 | 02:47 PM
Frank Fontaine's Avatar
Whew I thought I was the only one floored by a Maxima rear axle seal leaking. That's a common problem on Volvo 240's after about 150,000, the axle cover, bearings, seals, and universal joint and carrier bearings all go bad. Spotting gear oil that is sprayed under the car and on the exhaust system is a sign.
Not having any of these parts has saved the auto industry millions upon billions over the last 30 years--just not sure how they convinced the general public that FWD is better!
Old Jan 14, 2005 | 03:02 PM
Ant96GLE's Avatar
They used outdated Toyota transmissions... same as my 82 Corolla had
Old Jan 15, 2005 | 10:39 AM
eturnl
You're talking about rear wheel drive vehicles are you not? and what did you mean by:
"Whew I thought I was the only one floored by a Maxima rear axle seal leaking."
i didnt understand your post at all... can you explain better please?
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Huttig2009
Sep 25, 2015 03:31 PM
Starrider
Sep 17, 2015 07:26 AM
carlosvq30
Aug 17, 2015 11:32 AM
